Can anyone post up any pics of the mods to the oilways in the head & block. I'm just wondering which ones to drill out & which ones need opening/funneling out.
Cheers
Stu.
Very simple, all of the returns to the sump.
If it's not an oil return, then leave it alone.
Cheers
Gary
SydneyKid there is a hole in the block near to oil return... Is it a good idea to return the oils from the head there?
Depends on what block, generally speaking, no there isn't. That's why the suggested return is into the top LHS of the sump.
Cheers
Gary
  • 3 months later...
hey there,
just a question, ive read so much about the oil problems RB engines have, these cars arnt cheap to but, so much technology goes into development of these machines, and there seems to be about 6 problems with the oil side that sydneykid lists, why the hell have they not developed a better system of oil supply when testing their cars? or maybe nissan should have hired someone with a brain (sydneykid) to do the most critical part of a car engine????????
hey there,
Ask Nissan???
If the GTR's were used and driven as a stock road car with no power mods etc, they would be fine 90% of the time.
They did fix the oil pump drive from late R32GTR's onwards(thats about it).
As soon as you push beyond factory specs and set limitations, that's where all these mods come in handy I'm sure.
I was lucky enough to see the inside of the engine that gibson motorsport built for kerry packer's car back in 91 last week. while they had made some mods, they didn't have:
external oil return
restrictor in feed to head (in fact they had opened both feeds!)
wide drive on the oil pump
expanded internal oil return at the rear of the block.
I think it is fair to say the development that gary and the race team have done on these motors over many years, and they fact they have been willing to share the knowledge at no cost is very valuable to everyone on these forums
oh, and it spun a bearing on its first track day....
external oil return
Ouchhhh! That's expensive. How much was the engine back then....~150-200g?
Dunc, what changes have been made on the engine/car that caused the spun bearing? Was there any new oil pump, was the rpm limit raised, stickier tyres etc etc?
Cheap compared to a f--ked engine or engines especially if you plan on doing a lot of klm's on the track.
Dazmo, what kind of dollar is it for your dry sump and is there anyway of fitting one into a rb with Aircond and power steering intact :D?
You drill the smaller round holes to 9mm right?
I'm drilling mine out to 10mm, to match the head gasket.
Diameter of one of the oil drain holes, where it steps to the larger diameter is 9.65mm, and gasket was 10mm.
    • I got the four AN10 fitting welded up to the cam covers and started up making the head to sump breather/drain lines. The front passenger side cover I used a 45 up top and a 90 at the bottom into the stock VCT head drain spot (3/4" BPST to AN10 adapter) thats unused on the RB25DET NEO with some speedflow flame shield to protect it from the manifolds heat.   back passenger side was a 90 up top with some flame shield and 45 at the sump end. The rear drivers is 45 at both ends   the front drivers fitting is capped off for now but ready to go if i want to try moving the breathers around. I was told by the fabricator to leave all the welds raw for now to make sure there are no pin hole leaks. A lot of cleaning up, re bundling looms and degreasing to go as well as final assembly on the cam cover baffles. The first real test will be 28th March at a Circuit event. added complexity and more spots for leaks but overall looks relatively neat imo
    • Yeah i think the dash needs to come out. To get the loom or maybe just climate control and radio cluster. My mirrors are done i think the motors don’t work so well after flood haha i need the ac fan, you said you wanted to keep it for your 31 and interior loom not including boot. The wiper motor. I’m not sure how good the window surrounds are on the exterior on the pintara.  I will message you to get your bank details shortly
    • Just another barrier put up to stop cars being modified. When we're all driving Chinese sewing machines, you won't want to modify it anyway, and you'll likely already have slashed your wrists and be locked up in a padded room for your own protection.
    • Yes, but no. I wouldn't want an IC7, because I think they are ugly, cramped and most of the displays I've seen are garish (and granted the last bit can probably be avoided). I wouldn't want to pay for the UC10. Probably wouldn't want to pay for the IC7, for that matter. And, it's an R32. I have cable drive speedo. Although, thinking about it, that's not a big obstacle, because at least I can throw the electronic sender back into the R33 box and then find a way to emulate the original (R32 or R33) speedo head's conversion of the saw-tooth AC speed signal into the square wave that the ECU wants, without the 1990s approach of hiding a gutted speedo head behind the dash. (another Arduino project, no doubt). I like the technical aspects of the big digital dashes, but I aesthetically and just general originality and feel-wise, like the original dash enough. More? Yes, more. If I had a UC10 I'd want to make the dash look as close to the original one as possible most of the time, and only flash up "DANGER TO MANIFOLD" when it needed to. But the other aspect of the 3-DIN slot digi gauge that I'm contemplating is that I'm a tinkerer and can barely resist a project, even if I don't need to add another to the list of unfinished ones. And I think there's enough precedent of others out there that have proven which equipment works (ie, is not washed out, or slow, or prone to failure, or all the other problems that can afflict such a project). I'm not quite enough of a micro-controller tech head that I know the best way to approach all of these decisions, and so striking out on my own to achieve it years ago would have led to unhappiness. But now, it seems like a project that I can actually achieve on the first or second go, with only a few sleepless nights. And that's why I'm actively thinking about it now. I would much rather have a thing in my car that I made from more-or-less scratch that does what I want, rather than something that someone else made that does some of what I want, not other stuff I want, and/or annoys me in some fashion. If I'm going to be annoyed, I need it to be my fault, so I know who to blame, and who needs to fix it. As an example of that - I have surveillance cameras at home. No, I did not go buy a kit with a DVR and 4 or 8 or 16 off-the-shelf cameras in a kit. No, I did not want to use any sort of could service to record or access the feeds and recordings from outside the house. No, I bought my chosen cameras directly (from China, lol) and built the DVR myself using a couple of different (ie, this was attempt 1 and attempt 2 to get a system I liked) software packages, running on Linux, with the server being a virtual machine running Proxmox. I found a way to offload the image recognition part of the system to a dedicated AI processing board (a Coral TPU, for anyone who cares) with the hardware passed through to the server on the VM, motion detection offloaded to the GPU, all storage is local in the home network, accessible from outside via my own self-hosted VPN). All done so that I could seal off the Chinese cameras in their own network where they can't access the internet and dial home to the CCP and backdoor my network. All things that you can't have if you do what is commercially available. And even with all the f**king around it has still cost a fraction of what it would cost to buy commercially.
    • ..could be worse... but out here, renting private affords some luxuries ...we've even been told the Sept dateline isn't critical, and I'd rather move stuff in the cool of winter, than slogging it out in the heat. Recall we were talking about the million dollar view this place has?...that's what he got for it... (won't be so nice when the quarry happens at the back in the future...lol..)... ...cool, I'll stick the wiper motor in a wee box...umm.... the pinny is GLX trim ~ I think that's about as close as it gets to Silo spec when it comes to the S2 pinny...ie; electric mirrors etc etc...dunno about the trip computer/wiring...I do electronics repair, I'd be willing to take a look at it for you. As you saw, all the dash is there in that car..and thinking about it, it'd be easier to pull the whole center section out, rather than just the ashtray and rails, but your call...
