This thread is out of control. There is a lot of information and I am lost. I've read pretty much all 33 pages minus 1 or 2.
What I got out of it was (for my setup, mostly street but sometimes track bnr32 Rb26 with an N1 Oil Pump and r34 crank) was the following:
- Run a 1.5mm restrictor (only need one correct?)
- Run a drain from the back of the head to the sump just above the fill line on the sump on intake side
- Run a catch can that vents to atmosphere, drain to the sump above the fill line on intake side (PVC block, lines from each cam cover)
- Enlarge the oil returns by 2mm
Can someone please correct me if I'm wrong on any of this or if I should do something different. This thread help me learn alot but now I'm confused on what to do.
Thanks
Mitch
Thanks
Mitch
Oil return from head goes to exhaust side of sump so oil gets sucked out rather than blown up. Other than that, looks good.
Thanks. I'll put both the drain from the oil catch tank (or as the manufacturer calls it, a breather tank) to the exhaust side of the car, and the rear head drain also to the exhaust side. Some people in this thread say dont drain from oil catch tank to sump, others say to do it. Then people say to drain to intake side cause its cooler, then others say drain to the exhaust side for vacuum. Very confusing, but a top notch read.
Edited by mitch32
i plumbed mine drain from the back of the head into the return line from the turbo :) if Nissan make that a drain spot it wouldnt be wrong you would hope.. works well :P
the sump breather should be on the intake side so more blow-by goes out the breather instead of up the oil returns due to the direction the crank spins. Head drain to exhaust side and sump breather to intake side is the go.
Yeah Cubes decided it was mature to PM me calling me a grease monkey (he has no idea of who i am or what i do) then boasting how he was a lawyer or in law school. All this tirade after all i did was point out the group buy he was running was in doubt as i knew the parts he was offering were unavailable as one of my suppliers had them on back order for 6 weeks. He then trawls the site and finds a post where i had a crack at SK and issues me with a warning to get back at me. He's a good thing gone as far as im concerned.
cheers for clearing that up Slaps. :ninja:
Not quite.. my supplier at the time stated they had the amount i required in stock. You popped your head in to the thread quite rudely.. instead of politely advising me of your 'inside information' you were damn rude and obnoxious about it.
I flared up understandably and requested you keep to yourself. yes calling you a grease monkey you replying "no im not, im a property developer" :)
A few days later I went to place the order and BAM.. sorry there was recently a large order placed we dont have any available.
Mind you this was back when Z32 AFM's were expensive.. I was the first to offer them at $280-290 on SAU, maybe the group buy saw the demand for Z32's at that price and made a few look in to a large order. Who knows. It sure damn seemed like it at the time.
As for the warning... LOL. I don't remember it but I'm sure you deserved it the way I've seen you speak to some. :ninja:
Edited by SLAPS
Some people don't like to accept they sometimes make errors...and when its pointed out to them have a tanty and get all narky. As it turned out you couldn't supply the product you originally stated you could so as it stands my comments were vindicated.
I am an electrical engineer by trade but also dabble in a bit of property development which i always have a least one project on the go. If you would like to view the completed development project i was undertaking at the time go to http://www.torrenbell.com.au/ then click on portfolio, units, diemar to view. :D I hope your law degree (or whatever you are studying) is going well, but remember when you are loosing an arguement regarding a point of law name calling is going to get you nowhere.
Im sure ive had a crack at a couple of guys on here but hey ive earned more of a reputation helping people out and doing quality work on not only my own cars but others as well. I freely share knowledge gain from developing and testing our own cars...sometimes proving or disproving various 'theories' that circle the internet. This testing is done on our own budget and at times incurrs substantial cost but handing these findings on to the public forum to help people out does give some satisfaction. A couple of the major workshops have been a little critical of why i sometimes do this as they are aware of how much time it has taken them test and prove various products/systems.
You could have left this way in the past but you were the one who decided after all this time to dredge it up again. Very silly and childish of you. :ninja:
On topic.
Edited by DiRTgarage
Thank you for making my point for me. There is no "oil stuck in the head" problem. It's a crappy sump design problem.
No no.... My RB25/30 pumps everything to the head, then out the oil breathers... There is sdefinitely a problem at sustained RPM.
The other big thing, most RB26 that are spinning big ends are doing it in GTRs... Which manage to turn with ALOT more G-Forces then the RWD brigade do... :blink:
Dirt.. will take this to pm. Keep it clean this time :down:
cool :blink:
yes and yes
Thanks
Mitch
Most people that deal with RBs will tell you to elarge and baffel the sump... wasent on your list, but i've found it to be the most recomended mod, so probably something you might want to look into
Come on guys.
23 years of developing RB engines and we're forced to run butt ugly laundry hoses from corner to corner across our engine bays !
Most of our engine bays looked better than our wives before this S... started.
Come on guys, think.
There's gotta be a better way out of this for those of us poor souls whom built engines before this was COMMON knowledge.
:laugh:
Has anyone tried running completely unvented ?
How much pressure is really going to build up? Strong enough to blow gaskets ?
I have RB25/30 Tomei 1.5mm restrictors front and rear, VVT left as is, and N1 pump, no rear drain.
I may consider running my pcv directly unvented to my dipstick.
After turn 1 at Eastern Creek, I had nothing on decel, but once I booted it to turn 2, I had a continuous plume all the way to the turn. I'm assuming the pcv outlet is the culprit for the oil spew into the plenum.
I'd be hesitant to say with all the oil pressed against the front right corner that spewed through the bridge, and up through the s bend into the intake.
Another thing that satisfies this is that my BOV is uphill from the intercooler as least 30mm, so when parked the oil must have run down from the plenum.
After the 10 min session I observed atleast 70mm oil drop out of my undermount BOV.
Now the intake side breather. Take the left side rocker off.
What about fitting another breather entry at the rear directly over the main oil drain. Then leaving the left to right bridge pipe in tact, bridge another from front to rear, left rocker only.
If the head is full of oil , on decel it'll be all at the front, and either go down the pcv to the sump(RHS) or spew back through the new bridge directly into the rear internal drain(LHS).
How does Nissan deal with blow by in the VR38DETT as it's under a pressurised lubrication system ?
It's described as 'pressurised' not vacuum so I'm assuming it's positive.
Still not convinced with catch cans.
Cheers.
I'm not a mechanic so don't bite my head off.
But my instinct tells me laundry hoses are not the final chapter for the infamous RB !
Cheers.
block all the breathers and the turbo will smoke so bad youll think its on fire
  • 3 months later...
can all the gurus here make a consensus which to use....
street...
circuit
drag
drift
rb20...
rb25
rb26
rb30
and all the in betweens
been reading all 34 pages, confused! :D and w/ a headache with all the terminologies and technicalities...
shed some light to those lay people like us...
thank you in advance! great thread btw!
Edited by zephyro90
it has been a tricky read. i hope i got mine right as i just got my motor back from the shop. rb25 used for drift and circuit.
baffled and enlarged sump
oil return at rear of head to the sump
restrictor in the middle oil hole.
fingers crossed i have not created a problem.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
