For a car that does regular track days and hard driving should be ok, but when driven on cold nights etc would pay to be blocked return
Block it off and do another 2500 then do another test to see if it effects the rseults.
  • 4 months later...
Hey guys just want to make sure im on the right path here... Car is 95% street driven but 4 or 5 track days a year.
RB28 is currently with engine builder and have the following being installed
- 9 litre sump
- Nitto oil pump
- Rear head drain to sump
- Mines rocker cover baffle kit
- Oil restrictor size? 1mm with nitto pump?
- Oil air separator and catch can set up
I will check on monday to see if this is going to be done
4. Drill out the oil return galleries in the head and block
5. Machine around the oil return galleries to facilitate access for the oil
Anything else Im missing out?
I wouldn't bother with the so-called head drain to sump. No-=one has been able to show that it drains any oil. Better to run a breather from the sump to a catch can. My RB30 (different from yours) has two holes tapped in sump and one line goes to top of tank and the other is a return as at WOT a fair bit of oil is pushed out.
You obviously need to do all the drilling and relieving before the block is cleaned.
1.0mm restrictor sounds right
Mines rocker cover baffles seem to work
Oil air seperator and catch can sound good - going to eventually vent to intake or atmosphere?
Cheers thanks for the advice!
Im pretty sure were running a return to the sump as I did request that. I dont think they have started with the block yet so Ill give them a call on monday. They probably already are doing this as they have worked on a lot of gtr's before but better to ask the right questions and do the job properly once. With the catch can setup probably going to vent to atmosphere, but Im not sure what they have planned. Does it make a difference apart from legalities?
I don't think so. I am currently running one catch can for the sump breather and the cam cover breathers. By now there is pretty much nothing coming out of the cam cover breathers but the breather/filter for the catch can at WOT exudes some oily mist (just nuisance value) so my plan is to run just the sump to one catch can and run the breather from that and the cam cover breathers to a second catch can set up as an air oil seperator and either vent that one to atmosphere or preferably vent the second one (assuming there's virtually no oil coming out of it) to the turbo intake pipe.
  • 1 month later...
Bumping this up,
I know the topic is for drift drag etc,
But do the rules still apply for street use?
I've bought a nitto pump coz I don't wanna break n1 pumps etc but seeing as the nitto pump flows a lot more oil at 7000rpm then standard this would pool the head therefore oil restritors would be used to limit the oil going to the head (plus other oil control)
But for a street driven r33 rb25det VCt daily driver that isn't going to see high rpm all day long only few street pulls and 1 1/4mile
If you were to restrit the oil going to the head wouldn't this result at lower rpm (cruising) for the hydraulic lifters to be noisey?
Seeing as litres/ per min nitto vs factory is
Engine rpm. Factory. Nitto
750. 4.6. 6.5
2200. 15.3. 20.2
7000. 46.5. 64.8
Pretty much I'm trying to fine out what oil restritors I need to not pool the head up high rpm and still be suitable for street daily cruising?
Leave the front, block middle, 1.5rear
Leave the front, block middle, 1.3 rear
Leave the front, 1.2 middle, 1.2 rear
I have been told to do this? But with the 1.5 rear I've heard of noisey lifters?
This may have been covered for other oil pumps but have seen anyone talk about it for a nitto pump and street use
Thanks for any help
You need to get pressure set to a suitable pressure for your engine first. I run a tomei pump, makes 35 psi at idle when hot and regulated to 70psi. I also have 2x 1.3 restrictors and lifters arent noisy but you can hear them. I do recon my restrictors crushed to about 1mm
Remember what the pumps free flow and what the pumps flow when both are set to exact pressure is different. 70 psi of oil pressure is 70 psi. Unlike air or compressables, its hydraulic. They both move the same at given pressures with a given restriction.
Basically if pressure is set, flow is irrelevant between pumps
Hmmm everyone I have rang (fair few shops) including nitto, can not tell me a straight answer which makes me wonder!!!
I've been told again to do
Leave front, 1.5mm middle, block rear
Also everyone I have rang has not said anything about adjusting the pressure? Even nitto
Whats nitto's pressure set at? You dont want excessive pressure. I got lewis engines to set my pressure for 40 bucks... Highly reccomend especially if internal relief valve which means engine out
What size did you go?
Also nitto recommend not to adjust the pressure valve :/
As above i left vct std, and 1.3mm in the other two. They crushed down to more like 1mm. Using 65-70 psi... Ask what the pressure is set at.. I wouldn't go any less than those restrictions as at idle lifters in mine are more audible...
Remember 1x 1.5mm flows over 2/3 the volume of 2x 1mm restrictors
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
