Narrow it down to ill be setting pressure to 70-65psi
Narrow the restritors to
Leave VCt, 1.3mm in the other two
Or
Leave VCt, 1.5mm and block rear, (or should this be block middle 1.5mm rear)
Abr33 are you running a head drain? Also are you running bigger sump with extended pickup?
Doesnt really matter which oil feed gets blocked, it all runs a common gallery for lifters...
I have a gated and baffled sump that I made with better pickup, holds bit over 7 litres. If you need pics I think I put them up several pages back or can send more.
And have a rear head drain/vent also enlarged oil return channels and drilled return holes to 9mm. Also running front of sump to cam vent but will send it to a can soon.
Don't block the rear oil feed it does matter, block the centre at 75 to 85 psi max hot oil pressure if you leave the front restrictor std (which if you want the VCt to operate you should) and block the centre then reducing the rear to as little as 0.9mm combined with using a high volume pump so as oil pressure at idle is 30 psi or greater hot the lifters won't rattle.
So many mixed story's, this thread has a graph on the first page and that says to block the rear?
Fine on a gtr head with solid lifters and no VCt. You have VCt and hydraulic lifters yes? Then don't block the rear, your engine builder would know this if they don't be concerned, mention loss over distance and gauge the response , trust me block the rear and the lifters at the rear of the head will define it for you.
Yeah running hydraulic lifters and VCt, the engine builder didn't wanna put any in for the fact of noisey lifters...
Nitto website says dual spring crack off is 120psi... Single spring crack off is 75psi??
Should I do the single spring to give me the 75psi if this is max?
Hello all.
I've searched but havent found the answer I'm looking for....
My motor is a Stock S2 RB25DET, standard bottom end and oil pump. But has Tomei Poncams and Hi flow OP6 turbo.
Its only street driven but with occasional drags.
What restrictors should I fit.
SK has said Leave VCT, block center and 1.5mm for rear.
From my searching I have found that the standard RB25DET restrictors are already 1.5mm. So all I need to do is block the center one?
Or is there no point in even removing the head to just to block off one restrictor with a stock motor?
Cheers
I am getting a bit of oil through my cooler piping etc as its running the stock breather hoses off the rocker covers.
Will look at a catch can.
Btw motor is out of the car at the moment, hence why I'm thinking of pulling the head to do the restrictors...
  • 1 month later...
Hi everyone my name is stef..I hope someone can offer me some advice as I have read this hole thread from start to finish!
I'm in the middle of a forged rb25det build with an n1 oil pump.. After reading this thread I have come to the conclusion that I need to leave the vvt, block the middle and restrict the rear to 1.5mm. Now upon stripping the engine which I believe has been untouched I have found that all three restrictor a are 1.2mm which has now confused me lol..should I still block the middle supply and drill the rear out to 1.5mm? Thanks for any help
Regards
Stef
Yeah I just got the head off mine this week. The front vct is 1.5mm and the other 2 are 1.2mm
Motor is a S2 RB25DET from a 95 R33.
So should I just put in 2x 1mm?
Depends on what pump you are using. I have an N1 pump RB30 block S2 head and I'm successfully using 2 x 1mm restrictors (street. track and to come - drags).
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
