Narrow it down to ill be setting pressure to 70-65psi
Narrow the restritors to
Leave VCt, 1.3mm in the other two
Or
Leave VCt, 1.5mm and block rear, (or should this be block middle 1.5mm rear)
Abr33 are you running a head drain? Also are you running bigger sump with extended pickup?
Doesnt really matter which oil feed gets blocked, it all runs a common gallery for lifters...
I have a gated and baffled sump that I made with better pickup, holds bit over 7 litres. If you need pics I think I put them up several pages back or can send more.
And have a rear head drain/vent also enlarged oil return channels and drilled return holes to 9mm. Also running front of sump to cam vent but will send it to a can soon.
Don't block the rear oil feed it does matter, block the centre at 75 to 85 psi max hot oil pressure if you leave the front restrictor std (which if you want the VCt to operate you should) and block the centre then reducing the rear to as little as 0.9mm combined with using a high volume pump so as oil pressure at idle is 30 psi or greater hot the lifters won't rattle.
So many mixed story's, this thread has a graph on the first page and that says to block the rear?
Fine on a gtr head with solid lifters and no VCt. You have VCt and hydraulic lifters yes? Then don't block the rear, your engine builder would know this if they don't be concerned, mention loss over distance and gauge the response , trust me block the rear and the lifters at the rear of the head will define it for you.
Yeah running hydraulic lifters and VCt, the engine builder didn't wanna put any in for the fact of noisey lifters...
Nitto website says dual spring crack off is 120psi... Single spring crack off is 75psi??
Should I do the single spring to give me the 75psi if this is max?
Hello all.
I've searched but havent found the answer I'm looking for....
My motor is a Stock S2 RB25DET, standard bottom end and oil pump. But has Tomei Poncams and Hi flow OP6 turbo.
Its only street driven but with occasional drags.
What restrictors should I fit.
SK has said Leave VCT, block center and 1.5mm for rear.
From my searching I have found that the standard RB25DET restrictors are already 1.5mm. So all I need to do is block the center one?
Or is there no point in even removing the head to just to block off one restrictor with a stock motor?
Cheers
I am getting a bit of oil through my cooler piping etc as its running the stock breather hoses off the rocker covers.
Will look at a catch can.
Btw motor is out of the car at the moment, hence why I'm thinking of pulling the head to do the restrictors...
  • 1 month later...
Hi everyone my name is stef..I hope someone can offer me some advice as I have read this hole thread from start to finish!
I'm in the middle of a forged rb25det build with an n1 oil pump.. After reading this thread I have come to the conclusion that I need to leave the vvt, block the middle and restrict the rear to 1.5mm. Now upon stripping the engine which I believe has been untouched I have found that all three restrictor a are 1.2mm which has now confused me lol..should I still block the middle supply and drill the rear out to 1.5mm? Thanks for any help
Regards
Stef
Yeah I just got the head off mine this week. The front vct is 1.5mm and the other 2 are 1.2mm
Motor is a S2 RB25DET from a 95 R33.
So should I just put in 2x 1mm?
Depends on what pump you are using. I have an N1 pump RB30 block S2 head and I'm successfully using 2 x 1mm restrictors (street. track and to come - drags).
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
