Work out the % of increased flow in your oil pump over standard and reduce the restrictor size by the same amount if not slightly more if you rev it.
There is a fluid flow vs pressure vs hole diameter formula you will need. Plenty of online support.
Thicker oil will reduce flow.
Another patch is a scavenger pump from head to sump. Works fine. Plenty of OEM cars use this method. VDO do a specific pump.
Matt
Other than that. Don't run your breather to vac. Go atmo if you have a MAP sensor. Vac encourages the oil to stay in the head. Provent do a catch can that regulates pressure to keep less of a differential from head to sump encouraging flow back down.
& I've read heaps of pages & couldn't find anything
The answers are all in the thread. If you get it wrong you could blow your engine. I could spell out what to do but your next question could (and should be) "why?". .. and then I would have to re-type miles of stuff that I and others have already contributed. You need not only to know what to do but to know why you are doing it so that you are happy with your decisions. Probably the last third of the thread should give you the picture and in fact there is a summary of the important points towards the end somewhere. I suspect that you are too lazy to read it properly but if you genuinely have a comprehension problem (difficulty understanding what you have read) I apologise. In that case send me a PM and I will PM you some info.
  • 1 month later...
Can someone confirm my setup, fairly sure im on track but good to get feed back.
Goes like this
I have both inlet and exhaust rocker covers venting to a 3 port catch can. The third port is routed to the turbo intake so it will be under vacuum. I have retained the line from inlet manifold to pcv to inlet rocker. So whilst motor is under vacuum its pulling air out of rockers through the intake manifold. When its under boost PCV shuts and pulls air through the turbo :)
Its a neo motor so oil restrictors should already be in check.
Cheers
regarding picture, line to turbo is not hooked up and i realise thats heater hose lol was just dummy fitting
Edited by n_D
Goes like this
Cheers
Sounds like how I have mine setup and I have no issues
Hey guys
My setup is:
Both cam covers going to catch can with -10 lines
Blocked PCV
Catch can vents to atmo
Has other usual oil mods like reimax gears, oil restrictor (think 1.1mm) mines cam cover baffles, oil cooler etc
Now my catch can has another -10 thread welded onto it that has a rubber cap over it and not in use, should I run this somewhere?
I hear people run a seperate line from can to dipstick when giving the car a thrashin?
Does that just basically act as a breather and helps oil flow back down the head?
Is 2 lines from the sump to the catch can really needed? Surely the one drain line won't be full of oil all the time and would act as a vent?
Edit:
Also looking at this can unless someone can recommend a better can?
Edited by 33SOM
Edit:
Will it fit your car? Looks good but don't you know a local fabricator who could make you one for about half the price?
I had my first track day with my RB20 last friday.
My catch can is fairly simple : there is only two line going from the two rocker cover to the empty catch can which is vented to atmosphere.
Wrecker RB20 with stock internal, highflow turbo, 12psi/0.8b, 444cc injectors, Z32 AFM on standard S13 airbox with a cold feed, FMIC, FFP, STD RB26 oil pump RB25 filter support modded to accept a CA18 oil to water cooler and a 19 row oil cooler.
Standard clutch fan and 2 row 32mm copper radiator.
I run 5w30 valvoline synpower oil.
The weather was ideal, it was a sunny day with 20~25掳C.
The catch can didn't spill any drop of oil, no overheating and I stopped trashing the engine when the oil passed 120掳C.
I could run for 15 min (~8/9 lap) or so before stopping because of oil temperature.
I could run the engine 100% per cent during the session with plenty 8000 rpm shifting without dramas.
My main problem was the power steering reservoir which was spilling fluid way to close to the turbo. Time to install a cooler on the power steering circuit.
I just bought the R33/34 one from them for near double that ( but my one has the washer bottle as part of it ) and worth it for the non hassle off designing and fabracating, they are also not just an empty can they are baffled with SS gauze to actually catch the oil vapours :thumbsup:
I have a AN-12 running from factory oil return on RB30 to the bung I between the two 26 manifolds and a AN-16 running from block to Walsh/frost plug at rest of head on hot side
I have a AN-12 running from cold side of block to oil cap and one as a return from front catch can with one way valve
A catch can that sits on engine attached to the two cam cover breathers which I put a baffle plate into the two AN-12 line from that to the Hi Octane catch can up front then two AN-12 lines one back to the PCV and the other to the inlet of rear turbo
The block returns where drilled to 9mm and head to 10mm and the back returns die ground smooth
Will know if it works on the 22nd of September :D
Sorry my profile needed updating.. Car is a 32gtr.
I have emailed Hi Octane and asked if they could put in another -10 outlet while its being made.
Cheers
I got the return changed to -12 and an extra -12 up top for an extra $20, they where very happy to do what I wanted
Hmm I got quoted $30 for an extra -10 up the top.
Oh well as long as it works :D
I went in there in person and turned out I knew one of them so maybe that got me a $10 discount lol
I had a look inside mine with the flexi camera and it should work well :thumbsup:
PS they have a kickarse collection of 80s BMX race bikes :yes:
Ah ok. I was happy with the $30 anyway. Plus free postage so all good :D
rb20 dont have the problem
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
