Thanks guys for the help.... Can't wait to get this done to mine....Because my motor is out for Top end build and re-assembly and i might as well do that and the restrictor while its out.....This is a good as thread. lol. Thank god for the Aussie's.
  • 3 weeks later...
So would there be any issue welding the plug below the oil level for the external oil return?
I bought the rear drain kit from Dane at Densynz and he instructed to weld the plug below oil level because high crankcase pressure would cause the oil to stall inside the line..
There are two takes and i'm confused which one is the more functional route..
So who's blocked off the rear oil feed of their RB20 or R32 RB25DE non-vct head? (i.e only one restrictor feeding the head)
I've tried to see if the two feeds within the head are joined and be buggered if I can feel any vac through the rear feed. :S
Maybe its the way I'm testing it. I've blocked off everything there is to block and there is a good deal of vac on the one oil feed yet the other see's nothing. :D
I believe you can probably run it above the oil level so long as its on the exhaust side i think(could be inlet, have to check with someone who knows exactly) so the crank vacuum helps pull the oil out of the return. I would think exhaust side, as the factory scraper breaks the vacuum from the inlet side so it also being the low point of the sump would be coping all the oil and broken windage. Need gary to cross check my thinkings, he would know for shizzle.
  • 4 weeks later...
I've been putting it off for a very long time.
Finally bit the bullet put faith in SK, closed my eyes blocked off the rear, 1.5mm up front and there appears to still be plenty of oil flicking around in the cam covers. I'll put a few hundred kays on it and check it out but I'm certian it will be all good.
R32 RB25DE head.
I think an Apology is in order for Gary (Sydneykid).
I doubted his suggestion that a 1.5mm restrictor up front and rear blocked off was perfecty fine for the R32 RB25DE head with no VCT.
So I went and did it anyway :thumbsup: and it is 100% percent fine.
Plenty of oil up top; top ends nice and quiet; no tapping when it comes off a rev; its all good.
So my apologies Buddy!
I've checked catch cans and there's absolutely no blowby; completely dry.
Yours doesn't count as you have an additional feed via the VCT to the head. :P
My problem was I didn't know of any one with an Rb20DET or R32 Rb25DE non vct head that had run with 1 restrictor blocked and a 1.5mm up front. The R32 Rb25DE and Rb20 heads are near identical apart from slightly larger ports and the larger combustion chamber/valves etc. So I wasn't completely comfortable using the R33+ Rb25 VCT head as a comparison that it really did work without problems. :yes:
But yes.. Still more than enough oil floating around; I've noticed I can now see the top of the bucket where as prior oil was constantly filled 1/4 up the base of the cam so impossible to see the top of the bucket.
Hello guys, i think it was already mentioned but do you have any sources for the block off and 1.0mm oil restrictor for my RB25DET ? Where can i buy them ? Tomei is only selling the 1.5mm oil restriktor and no block off plug. Thanks in advance.
one thing i dont get is.. all the machining etc etc. lining up the gasket etc.. just how much oil do you think will have to "build up" to flow down the standard oil drains. all 18 of them. i rekon mayby 2-300ml at most..
i mean its all a good idea but is it really that efective? has anyone done any tests to back this up? like on a circuit car with the standard sump with and without the drain?
or is blowby the issue here, where it all blows up the oil returns slowing the return of oil back to the sump?
Dave, watching the amount of fumes/smoke exiting the catch can vent at high rpm on the dyno I'd suggest there is some resistance to the head return flow but not massive. Still not entirely convinced a return is necessary but if you are considering fitting one then at build is the only time that is sensible.
hans, it doesn't really matter but most go left as that is the natural lean of the engine and run it into the sump.
we tapped the left of the head and run it aroudn the back to the right of the sump in front of the diff - just enough room to fit it, although the fitting in the head will foul the standard boost lines that run around the bacl
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
