NP mate. it does not require welding but it will require your machineist to machine down the crank and fit it correctly. its not a easy job and you have to have the crank out of the engine to do the task.
what was the other question? did you read through this thread ? it has everything you need.
always balance everything that goes up and down and round and round. Might as clean up the crank too while there, any dags and casting marks clean it up and get it slippery smooth.
In regards to the RB25 , why is the front feed blocked off and the rear feed restricted but with the other engines its the rear feed that gets blocked off and the front feed get's the restrictor as per sydneykids table ??
we dont know where sydney kid comes up with his ideas but they have been proven to work time after time after time so its a good idea not to ask questions how he comes up with it...
I think it may be because the rb25 has hydro lifters and its required to have it setup that way to run them properly where the gtr has solids which does not need the same kind of oil configuration.
Mine is done as per Sydney kids instructions and its been running for 2 years and 363rwkw.
There are many others whos are running well too. I dont know why people have to question it all the time.
  SATO GTS said:
well i certainly do not know thats why i am asking these question's b4 i put the motor together .. i want to be 100% sure all is correct ..
  SATO GTS said:
in saying that guilt-toy if you install the non vct 25 head you block of the rear and feed the front but with the 25 vct head its opposite and both have hydraulic lifters..
thats is correct??
I run the non-vct RB25 head.
I blocked off the rear restrictor as the Rb26's are and run a 1.5mm restrictor up font.
Works fine no ticks, pops etc. Went from shit loads of oil everywhere over 5500rpm+ to a bone dry catch can. Still plenty of oil floating around in the cam covers. Prior on idle oil was puddled up to the base of the cam so you couldn't see the lifter. Now u can.
As a few have experienced; if you experience hydraulic lifter tick once the motor is warm its a tell tale sign the motors on its last legs. Recently happened to a mate of mine running an rb30det.
what went on your mates engine when it went ? i get lifter tick for about 5 seconds when i start the engine on cold startup only...
just wondering what went on your mates engine
Lifter tick when the oil was warm and poor oil pressure no bottom end knocks or noises. The lifters were silent when cold.
Mine is fairly decent on cold start up, I only get an occasional tick. I can't remember the last time it ticked but I haven't been driving the car during the week for a while.
The RB20 was the same. Occasional tick.
Yeah well i checked my oil change sticker and it has been 6000km's since a oil change!! so thats why they would be ticking.. oil is getting a little old but its 300v chrono which is known to last longer then normal fully synthetic oil.
will change it in the next week or 2 :) ooooopppss
thats a pretty over the top solution Beyond Horizon, you will never fit the standard piping back on if you go a fitting like that. A simple 90o angle with 1/2 hose barbs on one side and 3/8 BSP thread on the other can be tapped into the head just to the right of the fitting in that pic - much easier, smaller and about $3 for the fitting
But will it flow as well, bearing in mind we are talking gravity feed here?
Do you know where i can find some pictures of this modification you're talking about or do you have some ?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
