Hi all, i have a question, my 25, i built it, got it tuned (about 320rwkw), found out about oil problems, got scared and pulled engine out to fit restrictors and make sump bigger. To my horror the bearings were totally shot, and had been running dry at times obviously, anyway thats sorted, whole bottom is getting blueprinted as we speak. But what i want a second opinion on is, is putting a scavenge pump from rear of sump pan to front unnessisary? Iv made sump bigger, about 1.5L, and its baffled and gated, modified pickup, i have tomei pump set to 65psi. head restrictors, rear head drain etc. Reason i worry is when i do a hillclimb race of any sort, when pulling huge revs for really long times up really steep hills, will the oil flow back to front of sump? or is it a worthy setup? Its predominantly driven sensibly on the road, but i will do the odd race and track and skidpan day.
Now everyone will say go dry sump... Iv considered it, not going to do it the aircon is too valuable around here. plus its pretty dear. And i dont bash the limiter, so the tomei should serve me well. Iv probably missed some details... thanks
No i havent yet, but they look great? nothing restrictive about them. or do i need to take them oversize?
Now, plenty of oil?
Does anyone know if overfilling a bit is bad? what happens if your crank slaps the oil?
Now, plenty of oil?
Compare the half a dozen tiny oil drains in the RB to the 12 x 14mm oil drains in a JZ
So yes they are restrictive, most guys drill them out by 1mm as there isnt much room to move.
So drilling out the drains in the head and block. How do people actually go about doing this?
Just grab the power drill, a 9mm drill bit, some cutting fluid and go nuts?
Do they get a workshop to do it.
Or use a suitable drill press?
ok so no real problem with an overfill, ill attack the drains on weekend.
Has anyone experienced oil problems with restrictors and head drain with bubbles or starvation up really steep hills with big power?
I was going to use a 10mm bit unless anyone knows better?
This is for the rear drains yes, but what do people do about the 8?mm holes in between the cylinders?
As above run a 10mm bit through although it would be nice if someone could confirm having done it themselves.
I run 10mm, no probs at all.
die grind rear drains, drill others as they are round
Edited by jangles
The question still remains though. do people just get out the power drill with some cutting lube and drill out the drains to 10mm in the head and block and then chamfer the holes with a deburing bit.
Or do they get a machinist with a drill press/cnc to do it?
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
