  On 04/02/2013 at 6:37 PM, KiwiRS4T said:
What are you using the car for - street, circuit, drag, drifting? Is it going to be experiencing long periods of WOT?
hi mate, i would say a bit of all..but mainly fast road..just concerned about the stock 1.2mm restrictors. do you think i should block the middle one and leave the vvt and rear 1.2mm or drill them out to 1.5mm?
100% leave the vct, if you have 1.2mm in the rear already then I would put another 1.2mm in the middle, or block the middle and make the rear 1.5mm
I've got nitto pump with Vct untouched, middle blocked, 1.5mm rear
But think I should of went 1.2mm middle and rear
  On 06/02/2013 at 2:52 PM, skylinestx said:
Im still a little unsure what would be the best...either to leave them all at 1.2mm or block the middle and drill the resar to 1.5mm..
Anyone left the at 1.2mm? Cheers for any info
I've had front and rear with 1.2mm restrictors for some months now and no issues to report. Standard RB25DET oil pump.
Hi thanks for the reply..im not sure if the n1 pump will a bit too much and accumilate in the head..do they flow a lot more than standard?
i started reading about the RB a few years back when considered buying a GT-R which i now have and is currently being stripped. been reading up on oil system a lot lately but never having worked on a car other than changing tires this thread is a lot to take in when it comes to the technical side of things.
I understand the RB26 has some oil issues in the standard form when upping the power level and oil starvation is pretty scary to say the least. how would a leathal person with limited knowldge and money best tacke the oil issue? i plan on removing the engine this weekand, so this is pretty much the reason for me reading up on these things as of late. to be honest i came to page 31 and then skipped to the end due to technical understanding of things.
Ofcourse its inevitable that the engine will one day need a rebuild, question is how one can be as proactive as possible, most of you would seem to know a great deal and track your cars a lot compared to the normal skyline owner where I only intend on using my car for 3-4 track days per year and some spirited mountains runs (due to insurance my limit will be 5,000km per year) what would my best investment be on the oil-side?, will be running 450-500bhp on a pair of GT-SS (to be installed), currently have a N1 oil pump, completely new top with ACL race bearings, tomei 260 9.15 cams and cam gears that all was installed a year back after last owner blow the ceramic turbos. not having any direct mechanical experience (shell restoration is bit of a learning curve already) i would be happy to leave the block and top alone and away from drills.
Also been reading a lot of negative feedback about the N1 pump over at gtr.co.uk but over here it seems be a known issue of early crankshaft (barely know what that is), is this something i need to be worried about on a R34? so, what angle is the best to take on this?
Extended sump/pan?
tomei baffle plate?
oil cooler? (overkill if i go extended sump?)
other more important things i might need to consider first?
Christian
Edited by Christian P
R34 crank is fine.
Extended sump + baffles good idea.
If you do the above you can hold the oil cooler and see if it becomes necessary - easy to fit later.
N1 pump - suggest a set of Reimax gears with carefull assembly (recent local failure - haven't got to the bottom of it yet).
If you are reboring the block and it will be thoroughly cleaned drill out and relieve the oil returns.
Maybe get some feedback from other RB26 owners re oil restrictors.
Here is food for thought,
This is with a nitto pump so it's just a guideline for you as the nitto pumps alot more then n1
I know a guy with a rb26 with nitto pump, had 1.5m restritor in, high octance larger sump, rear head drain, and he was filling up the catch can... Ended up pulling head off and changing to 1.1m restritor problem solved,
Been rb26 it's solid lifters so you won't have drama with hyd like rb25
I've got a built rb26. I'm running a nitto pump 1mm restrictor in the block, sump baffles. Hi octane 3 stage cam cover baffle. Remote oil filter and 13 row cooler
Cam covers have two -10 lines run to the top of a catch can. The bottom of the catch can has two -10 lines which return to the sump. It vents to atmosphere and and it pumps a bit of oily vapor out the breathers. I believe it's coming from the sump. I can't put a non return valve in as it will stop the catch can equalizing the pressure from the sump.......any suggestions?
Edited by Shazz
Depending on the height of the catch can, as it needs to be lower, can you shove some stainless steel wool up the breather pipe and plumb it back into the intake? Most of the venting breather setups I have seen make a mess of the engine bay with oil vapour.
What do you mean by equalising pressure from the sump? I have two lines coming from the sump into a catch can to relieve the pressure in the sump and as Scotty says I get oil vapour coming out the breather so I have got a second, baffled catch can (or a proper oil/air seperator would be good) to take a line from where the breather was on the primary catch can and I will plumb the second one into my intake.
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
