Work out the % of increased flow in your oil pump over standard and reduce the restrictor size by the same amount if not slightly more if you rev it.
There is a fluid flow vs pressure vs hole diameter formula you will need. Plenty of online support.
Thicker oil will reduce flow.
Another patch is a scavenger pump from head to sump. Works fine. Plenty of OEM cars use this method. VDO do a specific pump.
Matt
Other than that. Don't run your breather to vac. Go atmo if you have a MAP sensor. Vac encourages the oil to stay in the head. Provent do a catch can that regulates pressure to keep less of a differential from head to sump encouraging flow back down.
& I've read heaps of pages & couldn't find anything
The answers are all in the thread. If you get it wrong you could blow your engine. I could spell out what to do but your next question could (and should be) "why?". .. and then I would have to re-type miles of stuff that I and others have already contributed. You need not only to know what to do but to know why you are doing it so that you are happy with your decisions. Probably the last third of the thread should give you the picture and in fact there is a summary of the important points towards the end somewhere. I suspect that you are too lazy to read it properly but if you genuinely have a comprehension problem (difficulty understanding what you have read) I apologise. In that case send me a PM and I will PM you some info.
  • 1 month later...
Can someone confirm my setup, fairly sure im on track but good to get feed back.
Goes like this
I have both inlet and exhaust rocker covers venting to a 3 port catch can. The third port is routed to the turbo intake so it will be under vacuum. I have retained the line from inlet manifold to pcv to inlet rocker. So whilst motor is under vacuum its pulling air out of rockers through the intake manifold. When its under boost PCV shuts and pulls air through the turbo :)
Its a neo motor so oil restrictors should already be in check.
Cheers
regarding picture, line to turbo is not hooked up and i realise thats heater hose lol was just dummy fitting
Edited by n_D
Goes like this
Cheers
Sounds like how I have mine setup and I have no issues
Hey guys
My setup is:
Both cam covers going to catch can with -10 lines
Blocked PCV
Catch can vents to atmo
Has other usual oil mods like reimax gears, oil restrictor (think 1.1mm) mines cam cover baffles, oil cooler etc
Now my catch can has another -10 thread welded onto it that has a rubber cap over it and not in use, should I run this somewhere?
I hear people run a seperate line from can to dipstick when giving the car a thrashin?
Does that just basically act as a breather and helps oil flow back down the head?
Is 2 lines from the sump to the catch can really needed? Surely the one drain line won't be full of oil all the time and would act as a vent?
Edit:
Also looking at this can unless someone can recommend a better can?
Edited by 33SOM
Edit:
Will it fit your car? Looks good but don't you know a local fabricator who could make you one for about half the price?
I had my first track day with my RB20 last friday.
My catch can is fairly simple : there is only two line going from the two rocker cover to the empty catch can which is vented to atmosphere.
Wrecker RB20 with stock internal, highflow turbo, 12psi/0.8b, 444cc injectors, Z32 AFM on standard S13 airbox with a cold feed, FMIC, FFP, STD RB26 oil pump RB25 filter support modded to accept a CA18 oil to water cooler and a 19 row oil cooler.
Standard clutch fan and 2 row 32mm copper radiator.
I run 5w30 valvoline synpower oil.
The weather was ideal, it was a sunny day with 20~25°C.
The catch can didn't spill any drop of oil, no overheating and I stopped trashing the engine when the oil passed 120°C.
I could run for 15 min (~8/9 lap) or so before stopping because of oil temperature.
I could run the engine 100% per cent during the session with plenty 8000 rpm shifting without dramas.
My main problem was the power steering reservoir which was spilling fluid way to close to the turbo. Time to install a cooler on the power steering circuit.
I just bought the R33/34 one from them for near double that ( but my one has the washer bottle as part of it ) and worth it for the non hassle off designing and fabracating, they are also not just an empty can they are baffled with SS gauze to actually catch the oil vapours :thumbsup:
I have a AN-12 running from factory oil return on RB30 to the bung I between the two 26 manifolds and a AN-16 running from block to Walsh/frost plug at rest of head on hot side
I have a AN-12 running from cold side of block to oil cap and one as a return from front catch can with one way valve
A catch can that sits on engine attached to the two cam cover breathers which I put a baffle plate into the two AN-12 line from that to the Hi Octane catch can up front then two AN-12 lines one back to the PCV and the other to the inlet of rear turbo
The block returns where drilled to 9mm and head to 10mm and the back returns die ground smooth
Will know if it works on the 22nd of September :D
Sorry my profile needed updating.. Car is a 32gtr.
I have emailed Hi Octane and asked if they could put in another -10 outlet while its being made.
Cheers
I got the return changed to -12 and an extra -12 up top for an extra $20, they where very happy to do what I wanted
Hmm I got quoted $30 for an extra -10 up the top.
Oh well as long as it works :D
I went in there in person and turned out I knew one of them so maybe that got me a $10 discount lol
I had a look inside mine with the flexi camera and it should work well :thumbsup:
PS they have a kickarse collection of 80s BMX race bikes :yes:
Ah ok. I was happy with the $30 anyway. Plus free postage so all good :D
rb20 dont have the problem
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
