this thread has turned into how to make your rb survive at the track without a dry sump
not dry sump talk
Quite right. I and a number of others have found that with the right combination of restrictors, sump breathers and a properly designed catch can system the problems can be overcome. My catch can vents to the turbo intake so is a completely sealed system. If there had been oil laden fumes going into the turbo I would have added another air/oil separator into that line but there was no evidence of that being necessary.
ASR do have extended sumps MrFIjiGold had a word with them and initially they wanted to use my car to design it however. Unfortunate happened and it's no more. I recommend you give them a call the big problem with out GTTs is that they have to design around the sway bar
He no longer has GTT :ph34r:
And the big problem with my GTT is i still have no oil pressure under braking hard with ASR sump...
Have you guys ever had that setup kill a turbo when to much oil gets blown into tge turbo. ??
I once had that issue in the early days, it didnt kill the turbos.
But it did end up smoking under boost like it had a blown turbo.
Ended up being oil had pooled in the intercooler piping just before the intercooler, cleaned it all out, was back to normal.
If you get oil mist going in it will probably be fine. If the oil-air separation stages fail to do a good job and you get large drops hitting the comp wheel, it could possibly do some damage.
I had the same thing happened to me years back. SAME thing really left me worried that if enough oil hit that wheel at high speeds it could destroy the turbo. Thats why I asked.
fatz you lazy bastard put some restrictors in, that's a big part of the problem right there. Oil does no good for your engine when it's all floating around at the top.
Lol. I would have though he would have done that with that setup looking so good. I would agree. Spend some time pickung the right size according to your pump options.
Lol you guys talking about pulling heads off and doing all this fancy shit
Meanwhile I am out thrashing the car at the track thus my over the yop catch can setup with scavenge
My setup also factors in when you engine starts to wear out it gives you options to prolong the engines thrashing life( now that the engine is blowing buy abit more I can activate the scavenge )
If I rebuilt the engine I would stick one in but f**ked if I am pulling apart a runner..... Once you let the Nissan out they are never the same
  • Like 1
Fatz has the idea. Drive it and deal with it rather than pulling the engine out and sitting at a keyboard arguing over the Internet with people that your engine will have zero oil issues and you will do it this way and they should to, and then you realise you haven't driven your car for over a year and won't for another few months when the person with the issue is out wringing their cars neck every few weeks.
Perhaps. I suspect that anyone who is serious enough to care about this stuff (enough to do something about it, that is) and is permitted to spend/waste money on their car by the domestic authority (wife) shouldn't be so short of cash that they wouldn't just buy and build another engine out of the car while driving the original.
I do a lot of car things the cheap way (or not do anything at all!) because between myself and my wife we know that it is just a waste of money, even taking into consideration the philosophy that anything you enjoyed wasting was not actually wasted. But if I decided that I just couldn't put up with the 9 or 10 things about my car that are currently bothering me, I'd just go spend the $10 or $15k that would be needed to right it all (properly). I think the engine building stuff really ought to be done the same way.
No. As I said if I thought there was a likelihood of that happening (e.g. traces of oil in the line to the turbo inlet) I would have put an air/oil separator in the line. My catch can seems to do what its intended to do.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
