Got to get block, have a machine, pay for workshop to ahve machine in, pay for consumables for machine (drills etc), pay for someone to mount up block to machine, pay for someone to oparate it for drilling.
That's where the costs come from
2 hours ago, czy18e said:
What about what size oil restrictors for non neo 25 head with NO vct? It's not on the chart?
Its the middle column - RB25/20 no VVT
Hey guys I'm doing my first rb25 build, rb25det head and block. I've been reading this thread for hours, super helpful. I understand with an rb25det vct head I leave the vct oil feed alone, block the middle and restrict the third. Okay now my question is I plan on going from hydraulic to solid lifters, so then do I restrict the front vct oil feed, block the middle and rear or what? i know the rb26 is solid lifters and the rear oil feed is blocked from factory, so the chart states restrict front oil feed and block rear. And do solid lifters rid of the vct? I'm a little lost there.
Rather than the stainless steel wool packed into a stocking has anyone tried sintered brass exhaust silencers (As seen on ebay and the like) to filter the oil.
I noticed that Mishimoto appear to use exactly that.
https://www.mishimoto.com/compact-baffled-oil-catch-can-2-port.html
Would be neater, surely?
Just gave my secret away. They work damn well...just use the biggest bastard/s you can squeeze in
  • 4 weeks later...
Hey guys I've had a good read of the last 10-15 pages but here goes.
ive got a rb25/30neo, it's a built motor with all the usual forged bits and pieces.
Oil wise it has an ASR 8.5L sump, n1 pump with billet gears, all drains in the head were enlarged and cleaned up. From memory front oil feed is blocked and 1.2mm restrictor in the rear. Stock rb26 cam covers with 2 3/4 hoses to a small vented can..
Never had any issues with blow bye or anything on 20-25 psi street-drag or dyno.
Just recently fitted a water meth injection kit and running around 30psi, all good on dyno and street but at the drags it started pushing oil out the breathers (about 400ml each run).
Have done a comp test and leak down test and all looks good.
I really don't want to have to pull the sump off. I have thought about pulling the head off and fitting a rear vent and tee'ing into the turbo drain (spool sells this kit).
Just looking for some other opinions
cheers
cheers
I don't believe that will do anything but if you are hell bent on it go ahead and report back.
A cheaper option would be to put another 400ml in each run. You can decide whether to recycle what comes out or not.
The real fix is a couple of 1/2 in sump breathers with one draining back to the sump.
And ideally you have a 2L catch can properly baffled and vented to the turbo intake.
I have mine like this. If I had to do it all again, I would probably do a separate drain port into the sump but I can't really be bothered now. Probably doesn't do much but its there
  • Like 1
Thanks mate, So don't worry about the head vent. And ideally the sump breathers to catch can are the go (which means engine out).
I was going to go a bigger catch can anyway.
If i was to tee into the turbo drain with a -10 or-12 and run that to top of a catch can would be of any help?
Decided I'll pull the motor out and fit the sump breathers and drain back etc and a couple other things. While it's out is it worthwhile just to do the head vent/drain whatever you want to call it as well l. Or it's absolutely not needed and save the $200?
  • 4 weeks later...
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
