Hi guys
just bought myself a GTR which has been resprayed but the paint is covered in water marks from the car sitting in a garage for a while.
Ive used meguirs paint cleaner and then polymer sealant polish over the top and the marks are still the same. Even a decent buffing with lots of elbow grease does nothing :D
on the windows ive used the armor all glass cleaner and still nothing
i thought i might try a cutting polish on the windows to see if that works to get a similar result to cleaning r33 headlights
what have you guys done with watermarks? what works and what doesnt?
do you think regular washing will eventually wear down the marks?
thanks, its driving me nuts having new paint looking all spotty!
and yes, the search button on SAU isnt the most helpful thing around
https://www.sau.com.au/forums/topic/110714-removing-water-markshow/
I had the same problem with watermarks on the windows of my old car. No matter haw many times you washed it and scrubbed the windows, the marks were still there.
I used a cleaner called "Gumption" it comes in a white and green tub i think and consists of a gritty paste. You should be able to get it from any supermarket.
With a bit of elbow grease, this worked perfectly and the windows came up like new. I would say that cut and polish would work as well though, just try it and see.
anyone with anything else to add?
i had trouble with my old vl with purple paint and i left in the sprinklers for about 3-4 weeks and in the sun, which baked the marks on and was impossible to remove. i used a little (very very litte) diluted amount of CLR in a bucket of water and it actually worked a treat. though warning it says not for use on paint but i was selling the car anyway and it didnt damage the paint at all.
still took alot of elbow grease but fixed it in the end :(
upto u if u wanna try it, maybe try a small non-visable area first and see how it affects the paint. i wouldnt be doing it on a black or really dark colour though.
Edited by CruiseLiner
  • 4 weeks later...
use t-cut colour fast..... gets rid of water marks, fine abrasions and scratches....
I use this too
All cut and polish pruducts and gumption work the same way!!
However I imagine the cut and polish products are gentler
Hang on a second - before you go and try all the Nanna recipes.
Are the 'water' stains calcium stains, ie white?
not really white like you would see in the bathroom, moreso, car thats been left in the rain and had the sun bake on the stains into the paint
what do you suggest if its calcium?
ive been slack and havnt tried anything yet :(
also, i didnt want to try t-cut just yet cause it is quite harsh on the paint (owing to past experiences)
If it is Calcium then try CLR Clear - but be careful with the paint work, ie try it on a bit on paintwork that is out the way & unseen first.
If it is just a water stain then try using dishwashing detergent - that will pretty much shift anything that is water soluble & a few things that aren't - like dead bugs. You will need to strip any polish off the paint first, otherwise the detergent won't get to the marks.
  • 3 weeks later...
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
