Same old question concerning BOVs.
Not asking what performance increase etc, or who owns what, or the legalities of vent to atm etc.
What i would love to know is, if anyone has seen Best Motoring Vol 5, can someone tell me by the sound, what BOV the AMUSE Supra (the white one) is using.
Or for that matter the yellow S14 off Best Motoring Vol 6.
If someone can help great.
For those who havent seen them they are an entertaining watch, even better now you dont have to import them yourself
https://www.sau.com.au/forums/topic/11077-i-hate-asking-but/
BOOSTMEISTER is correct in that external wategates do make a nice fluttering sound, but it's not neccessary.
The Yellow S14 off BM Vol 6 actually has a standard turbo. (From memory, been a while since I've seen the video). So no external gate there.
My car is equipped with a Blitz BOV (older version) and is plumbed back. The car makes a very similar noise as you hear from the S14.
https://www.sau.com.au/forums/topic/11077-i-hate-asking-but/#findComment-186451
Roy are you actually talking about the fluttering noise? sort of like a ssstt tt tt tt tt tt..
If so, then it is either that the BOV staying shut or it doesn't have a BOV at all.
The Blitz bovs all make a psshhh sound of some sort.
From what I can remember, that supra made a huge fluttering sound.. which would mean that he was NOT runing a bov at all or had the spring on too tight and it wasn't opening to make a noise..
https://www.sau.com.au/forums/topic/11077-i-hate-asking-but/#findComment-187914
Yeh ive heard people say you get the fluttering noise when the spring rate in the BOV is too high, but im not convinced. Not to say they are wrong, but there is too much anecdotal facts floating around.
Anyone familiar with Sports Sedans in the early 90s will remember the Peanut Slab sponsored Ford Sierra from NZ that use to come to Aus occasionally and destroy Aus sports sedans, including Keith Carlings brutal 300ZX. It like the Supra and 200 on BM DVDs made the fluttering noise, and this way a pure turbo race car, even some of the 80s touring cars (05 Btrock Seirra) made the fluttering noise.
Is it a fair assumption that turbo race cars wouldnt wind up the BOV spring to reduce its effeciancy???
https://www.sau.com.au/forums/topic/11077-i-hate-asking-but/#findComment-189147
Roy...
Those sieras of the 80's didn't run any BOVs..
Did you ever hear a psshht once from them? NO. they were constantly fluttering when off boost.
And I am pretty sure that you will find the Supra in the BM DVD doesn't run a bov either.
If you want the fluttering noise, remove the bov and get a steel plate cut to cover the hole where the bov was..
https://www.sau.com.au/forums/topic/11077-i-hate-asking-but/#findComment-192585
Guest MFX_R33
There are alot of factors DO NOT give you a BOV sound at all (internal or external). That myth has been around for years, and I have no idea how it has been kept up. As already mentioned, generally that fluttering noise is from the lack of a BOV, and it is actually the sound of the air being blown back in through the airfilter, as the turbo back spins. My car does this and you can actually see the foam filter flapping as it happens.
Blow off valves can make this noise too. This often has very little to do with which BOV you have (most BOV's have almost the same simple piston design), but where it is placed. I have found BOV's tend to make that flutter when there is a greater length of I/C pipework (generally with a front mount) and the BOV is placed closer to mid way along the pipework.
Jeff.
https://www.sau.com.au/forums/topic/11077-i-hate-asking-but/#findComment-192614
No bovs can't make that sound..
it doesn't matter where it is placed..
that fluttering sound CAN NOT come out of the opening of a bov.
The bov can only make one sound... a single release of air in one hit.. it can't open and close to make different fluttering sounds.
If you have your bov mid way along your pipes, and you are hearing a fluttering sound, it is not coming out of the bov.. it just means that there isn't enough pressure to open the bov.
If you want a fluttering sound, remove your bov and block off the holes... if you want a bov noise, fit one and adjust it so that the piston is JUST closed at idle and it will psshht every gear change..
It's not that hard.
There is no other way to get a fluttering sound from your TURBO car.
https://www.sau.com.au/forums/topic/11077-i-hate-asking-but/#findComment-192625
Really, maybe I'm deaf because my bov has been making this sound for almost 3 years now.
(edit) P.S. I know its the bov because I've had it on dyno's. I can easily see the bov shaking when the throttle is closed in accordance to the flutter. This noise is made wheter or not I recirc it or vent to atmo.
https://www.sau.com.au/forums/topic/11077-i-hate-asking-but/#findComment-192629
Poyz...
Yes.. maybe you are deaf.
The sound does not come OUT of the bov.
it comes out of the air filter... listen closely next time..
The BOV piston might bounce up and down but it doesn't open and close does it..
It doesn't matter if it is atmo or recirc... it just means that it is not opening and therefore the air is going back through the turbo and getting chopped up going CH CH CH CH CH as it goes through the turbo blades which are spinning at like 80,000rpm and the sound can be heard from the turbo/air filter area.
Some people are unbelievable man..!!!!
https://www.sau.com.au/forums/topic/11077-i-hate-asking-but/#findComment-192668
How about you come over here and visit me. I'll run an example for you.
Here's how I'll do it.
I'll start my car, put her in neutral and leave the handbrake on. I'll pop my bonnet, rev the thing to say 4000-5000rpms. Air filter makes a flutter noise. (Car didn't make boost, bov doesn't open)
Now, we do it again. This time I rev to 7500rpms. Car will build boost (<5psi), BOV opens. Two noises can be heard. One you already have heard, the air filter. The other is the BOV.
Take note of the noises.
Go for a drive, take note of the noises upon releasing the throttle, sounds exactly like the BOV.
Still don't believe me, then that's your problem.
https://www.sau.com.au/forums/topic/11077-i-hate-asking-but/#findComment-192699
Guest MFX_R33
GTST,
I manufacture BOV's and have done alot of R&D on the subject, and BOV's can make that sound. In my experience I have not seen a BOV mounted on factory pipework in the factory position, make that sound. I have run my car on the Dyno without the bov and you can see the RUSH filter actually being sucked in and flutterin when you back off. When the BOV is connected you can see and hear it flutter (mine is placed in an opening in the front bar the opposite side to the filter). I have also seen it on a mates TX3 where his BOV is also placed next to the I/C and it flutters.
I am also in Sydney. I am near Liverpool. I would quite happily meet up with you and prove it to you if you like.
Jeff.
https://www.sau.com.au/forums/topic/11077-i-hate-asking-but/#findComment-194605
My BOV is mounted in the factory position and in factory pipe work. I do, however, have a FMIC with extra pipe work. But with the factory plumbing to/from the BOV my car does indeed make this flutter.
https://www.sau.com.au/forums/topic/11077-i-hate-asking-but/#findComment-194624
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
