My 32 has a loud high pitch scream comming from, well I thought the turbo, orig, I thought it was the belts, factory ones were cracked and hard, changed belts to bosch items, but noise continued, it at first only happened under big loads at 4500rpm foot flat but now screams at lighter loads 3800rpm 2/3 throttle about 5psi, I can still get full boost with hardly any throttle without it, it is definately boost related. A friend however today told me that it could also a split in a plumbing joint, has any one ever heard of this happening before?
https://www.sau.com.au/forums/topic/11078-sreaming-turbo/
If it was the turbo but, and i am still getting boost what would it be bearings? I just read a fast fours mag artticle about the bbearing r33 turbo and they recon the bearing unit is pretty good, Quote "should out live the engine". I don't have a turbo timer yet but always give it 3-5 minutes on cool down after a flogging.
https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-183402
Yes, had my boost guage reading from the plenum, mabye should have set it up on the wastegate actuater pipeing as i think their is pressure drop through all the intercooler plumbing and the actual boost at th turbo's outlet would have been more like 15psi which is apparently too much. Also the cheap style boost control valve i'm ussing can give boost spikes to 15.5psi my guage.
https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-186424
Guest nismogtsx
Mine is due to a japanese man filing the front tip of the turbine...
Aparentlly they do this for rice factor. The air rushing past causes a very high pitched turbo squell.... I have had mine now for 12 months running 10psi and have had no turbo trouble and many have said it will let go soon.
I will drive it til it dies... Or i win lotto
https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-189294
  • 1 year later...
It was the turbo, Just went out for milk and came home with no boost, recon my cat is full of ceramic exhaust turbine blades, Just for reference was running 14 psi at the plenum apparently to much, still lasted for 3months. Time for something bigger.
r u getting a new turbo? or r u just going to get a steel wheel for the exhaust side and get it repaired?
did u have the car when it was on stock boost? or did u buy like that? and if u boosted it, then was the car running well on stock boost, cos i'm planning on leaving mine on stock boost for a while, until i either change the wheel or the turbos for something quicker, also when u fix it can u post up how the engine runs, cos another post here says that shit can get into the engine and kill it.
https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-986787
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
