Does anyone know the specs and dimension differences between the R33 2 door & R33 4 door? Specifically is there a difference in length, and can an aftermarket exhaust designed for the 2 door model also fit straight on to the 4 door model?
If not, are there any easy mods that can be made to the exhaust to make it fit? I have all welding equipment for steel and stainless I need to do the job, but would prefer not to make big mods if I can avoid it.
Thanks for any info you can give.
https://www.sau.com.au/forums/topic/110783-r33-4-door-v-2-door-dimensions/
4 door is 80mm longer behind the rear wheels, all other dimensions are the same.
I have a 2 door exhaust on mine, looks fine, in fact sits more flush with the bumper than most 2 door exhausts which I actually think looks better
Edit: Sorry, and 20mm taller
i also have a 2dr cat back on my 4dr and its doesnt stick out as much at the rear which i think looks better. if u want to push it out, you could always fit a spacer after the cat.
Welcome to the 4dr club :thanks:
