im putting the cams back in the the marks that i marked lol well i lost them,sooooo how do u line it up? theres some little dots on the gears so do i line them up with something? i was thinking the engine should be at TDC and those dots should represent TDC aswell maybe? also does any1 know the tourqe for the cam caps? and anything else i should know too would be good
https://www.sau.com.au/forums/topic/11079-putting-cams-back-in/
This is for a RB20DET (probably works for other twin cams, not sure about RB30)
Crank at TDC #1
Locate camwheel on the locating spigot.
Align the marks on the camwheels with the marks on the backing plate (approx 10am on inlet, 2pm on exhaust)
Hey Lowlux,
Check this thread
http://www.skylinesaustralia.com/forums/sh...=SERVICE+MANUAL
A couple of guys (Carlo & Jamezilla) have posted that they have workshop manuals for R33 chassis. This would surely list torque settings for the cam cap bolts. I'm sure they'd be glad to help.
The best way to get TDC is turn the crank 'til the timing mark on the crank pulley matches TDC on the scale. ( where your mechanic points his timing strobe).
hey blind elk theres actually 3 marks on the backing plate for each cam, there at 45 degree spaces, also the TDC mark is on the bottom pully at around 2 oclock on the backing plate isnt it,and theres also a line on the pully that u have to align it with,also if your 1-2 teeth out on the cam gears will this be enough to send some vavles into mr piston? or is there a little leway
Might be a common backing plate for the 4-cyls as well. The 6s (actually RB20DET) use the the positions I described earlier. You'll be able to tell if you're close, because the valves (ins and exs) on #1 will be closed and #6 will be just open (the inlet and exhausts will be on overlap - ins almost closed, exs just opening).
Sounds right for the bottom pulley, just be sure to use the LAST mark (as you turn the engine) - that's TDC, all the others are BTDC.
2 teeth on the cam wheel is about 15 degrees of crank - probably more than enough to introduce a piston to a valve. Near enough is NEVER good enough!
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
