Hi there,
Last night at the drags I experienced a failure with ATTESA. I was hovering around 7.5k for a launch, dropped the clutch only to sit there with my rear wheels spinning! I backed off the throttle briefly and then put foot back down on the accelerator only to slingshot down the track with awd working correctly. Any ideas why this could be happening?
There was no warning lights on my dash (although I believe this might have been disconnected as I do not get a warning light after plucking the fuse out for rwd).
Appreciate any help guys.
Edited by Remix-
Hi there,
Attessa doesn't remove wheel spin. To a degree it can only react to the inputs you are putting in.
To be honest unless you are running drag radials of some description 7500 is too many revs. I used 6000 to launch at the last hillclimb which was plenty - and that with more weight on the rear wheels & with R compounds tyres on a stinking hot day.
Hi there, I am aware of how Attesa is designed to function and that slight wheel spin is the norms.
Let me elaborate on my circumstances - After dropping the clutch I sat in the same position for a couple seconds not moving (I felt no front torque) from the starting line.
My rear wheels were spinning wildly and without any intervention from the front wheels at all (Attesa is designed to intervene around this time).
I backed off completely (ie no throttle at all), put my foot down again and attessa cut in immediately just as quickly as it cut out previously. I ran higher than a 3.0 60ft as a result of my excessive rear wheelspin.
This was my 5th run of the night (my previous 4 runs were fine and I was consistently netting 1.9 60fter's without problem).
Cheers,
Lyndon
Edited by Remix-
Maybe the transfer case is worn out???
Time for a rebuild if so.
Cheers for the reply RNGTR,
Due to the nature of Attesa cutting out so suddenly (as I had no problems hard launching earlier), I would assume that if it was a transfer case wearing/worn out that it would slip gradually rather than suddenly? (please correct me if I am wrong guys).
Edited by Remix-
REMIX- I had this exact same issue with my 32 GTR a few years back, and after about a year of searching, it turned out to be excessive resistence in the earth wire running from the body near the engine bay fuse box to the engine block (driver's side). My actual earth cable required replacement, but maybe yours has just a dicky connection or dirty contact? I suspect the issue may be amplified by the engines requirement for plenty of spark at the same time as tryin to engage the front end? Worth a look maybe?
Cheers.
a build up of air in the ATTESA system? from memory this would cause the front wheels to be very slow to engage, maybe even a couple of seconds. normally wen u go around a corner and put the boot into it, would the front torque split engage immeadiately? watch the guage for the torque split, see how quick it is to respond next time, or if it climbs real slowly. might need to give the system a bleed. i may be totally rong here, this is just off the top of my head, so if i'm rong, please correct me :(
Great replies, cheers guys.
This weekend I will check ATTESA diagnostics and see what comes up.
Marlin I will also check the ground wire you mentioned (any chance you could post a photo of the ground wire location?).
If I am still unsuccessful - bleed ATTESA time.
Edited by Remix-
Sorry mate, I don't have the car any more, but it's really simple to find, it's the only large diametre earth on the driver's side (approx 8mm dia.)...... runs from in front of the right stut tower to the right engine mount normally.
Cheers.
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 馃槑
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
