Hey guys!
Just got off the dyno with the R33, and guess how much power it's making with front mount, 3.5" cat back exhuast, turbotech boost controller running 10psi and a high flow panel filter!
A quality 104rwkw!! WOO haha. Not really, actually quite frustrated :P Luckily we know the cause of the problem, it's running WAY too rich 11.4% or something if that makes sense to anyone, apparently it's meant to be at 14% (though i could be wrong with the % i think its actually a ratio of something) Whats funny is that i've told 2 mechanics already that it's running too rich and they've said it fine, I told this one and he decided he'd put my theory to the test and i was right, for once haha.
Hopefully it's going to only be the O2 sensor, i've just hit 40,000kms now and apparently they go every 40,000km. so right now it's making about 80kw less than what it should be! I just cant wait to get it running properly :D
On another note, after installing the turbotech ive noticed that when im on full boost and back the throttle off suddenly the needle hits like 15-20psi very very quickly and drops straight back, is that spiking, or just normal?
https://www.sau.com.au/forums/topic/110818-just-got-off-the-dyno/
when you say 11.4% you mean the air to fuel ratio is 11.4
BUT... that is NOT the reason you are making only 104rwkw
i have an rb20det and with 10.5 AFR make 132rwkw. that is much more rich than you and more power also
i'd be looking at other reasons for your loww in power..
have you checked the timing?
cheers,
Warren.
yeah thats it, the air to fuel ratio, im not sure what it is off boost but on boost its 11.4...I've only owned it for a month and from the moment i started driving it i've always thought it felt way too slow for what it is. So i asked a few mechanics, they drove it and said it was fine..Finally one knew what he was talking about!
It doesnt feel OVERLY slow though, but not quick by any means. I won't be able to get a copy of the dyno sheet until next week unfortunately, today was just a quick freeby 20min dyno run to fit the turbo tech.
I'm hoping theres nothing too wrong with it! what else could be causing a big loss in power, theres no wierd noises, its making proper boost, no leaks or anything..And no the timing hasnt been checked, i'll make a note for him to check that though.
cheers
Edited by lukes146
when i first put my rb20 on the dyno, it only made 106rwkw.. it drove fine so i thought nothing of it
then i found out that the timing belt was on tooth out on the intake side!
the CAS (thing on the front of the engine that controls timing) had been wound around fully to compensate, so the car drove ok and i never knew until i played around with the timing.. it pinged when the CAS was set to the centre...
if a memchanic checks the timing he could identify this straight away (hopefully)..
of course, this may not be your problem, i am just sharing my experience in the faint hope that it might account for your lack of power
cheers,
Warren
my mod is similar to urs,
tho i dun have a FMIC, I got R34 intercooler, and split dump pipe,
I got 196kw, with AFR 11. at 10 PSI
Dyno varies but cant be that much different.
get ur 1 check, something isnt rite.
compression check maybe??? GL
Edited by RBFIRE
11.4:1 afr isn't too bad, it wouldn't explain the low power reading, i wouldn't be too worried about running a bit rich, heaps better then running lean. Post a pic of your dyno chart with the AFR reading on it and we'll have a look
If this tunner told you the AFR should be 14:1, piss him off and go elsewhere. My mate blew his GTR motor because the dyno person had no idea about turbo engines and thought 14:1 was normal.
With a whole bunch of mods my car has a AFR that hovers around 11.2:1 and makes 274rwkw. Even though it kill a little power, it is better to be safe. The AFR you have is definately not the reason for the low power figure, get a second run on another dyno.
generally N/A motors can be tuned leaner, around 13-14, but for turbo's you generally aim at around 12 or slightly richer.
if your tuner thinks 14 is an ideal af ratio ask him if he'll replace the motor when it blows up...
Edited by MerlinTheHapyPig
lol, Al. Who was this dyno operator? and i blame you for not pointing your mate in the right direction :P
poor Rb26 :D
The motor's shagged, get a compression test and leakdown test done and see what conditions she's in...
Might be time to start saving for a rebuild.
Correct me if im wrong but isnt this the car that recorded a 190rwkw on the dyno, and this year its down to 104rwkw... ouchie.
poor Rb26 :D
A un-named guy who is a gun when tunning commo's, but obviously doesn't know shit about forced induction. I was not aware of the dyno runs till it was too late, and the owner should have known better himself :).
Poor, previously health, original N1 block :(
new O2 sensor will fix nothing on your car
Actually if the O2 sensor is faulty then it will cause the ECU to dump a load of fuel in and make it run very rich.
Happend to my car and could feel a dramatic loss of power.
However if the AFR's are within acceptable range and the car revs out cleanly during dyno runs and car still makes no power then it is likely something more terminal.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
