Hi,
I have a 180sx with Mu Rotars and pads in 4 stud. The size of these rotars really limit the type of calipers I can use. The only calipers I found that would suit my rotars are from Endless and would set me back $2,300. I have also recieved alot of feedback from NS.com members that for street driving, the Endless brake kit would be an over kill. Someone suggested I try R32 GTS brakes since they are also in 4 stud and same PCB. I wanted to find out more about the R32 GTS brake set up because I heard that they are also in 4 stud. I am not really keen to do a 5 stud conversion becasue I got a set of 4 stud rims I really like.
What I wanted to find out is:
1) Dimension of R32 GTS rotars? The current rotars I use are 280x22mm
2) Does the R32 GTS use 4 piston calipers?
3) About how much should I be paying for them?
Thanks for any help you can give me.
Cheers,
Jon
https://www.sau.com.au/forums/topic/110852-r32-gts-brake-set-up/
While I'm not completely sure on the dimensions of the rotors, I'm fairly sure that R32 GTS rotors are 280x22mm.
However, I am very sure that they don't use 4 piston calipers.
Turbo models yes, non turbo models no.
Why not find out about getting the turbo 280x32mm rotors and 4 piston calipers and seeing if they fit... especially see if your rims clear the calipers.....
r32 gtst 4 pots up front
280mm rotors
redrill them to 4 stud
Thanks for the update. Looks like I have few options as to what calipers I can upgrade to. I do not want to re-drill just becasue it is suppose to be illegal. The car is driven by my wife and myself as a fun car and we do not really want trouble with the police.... that would not be fun anymore.
I may just stick with the current SR calipers for the time being. It looks small, and not very good, but $2,300 is probably too much to spend at the moment.
Jon
Hey mate I have just finised doing a GTR convesion on my cefiro, you can get R33 gtst front and rear, or 32 GTR or R32 gtst m (dont think type m had drum handbrake). Also need cable and the drum set up for the handbrake, all you need to do is match the caliper to the rotor. so unfortunalty your mu rotors wont fit anything else. And maybe Brake master cylinder. After doing the conversion I recon its one of the most rewarding, safe and enjoying mods you can do. You may be able to get away with a budget of about $800 for 32 type m and $$$$ go up from there.
Edited by cefiro
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
