hi just a question
i have recently done the mod to get 7psi all the time on my r33 gts25t
but why does my stock boost gauge go only over the "0" a little bit?
is that right? or is there something wrong?
please help
What was the stock gauge doing before you did the mod?
lol u haven't accidentally knocked any hoses off or anything when u were messing around with the solenoid have u?? Check and make sure everythings tight and theres no breaks in the tubing anywhere.
Should be halfway between 0 & 7 mmHg (7mmHg is 14psi so half way is 7psi)
:( I have a GTR 33 running 10psi not the stock 7psi and my standard boost gauge is just under 1/4. This is normal when the boost is turned up the gauge callabration and sensor's from the ECU say it's more than 0psi at idle, so the gauge is reporting correctly so to speak. It is really nothing to be concerned with. If anyone knows how to recalbrate the gauge or sensors please follow on from here.....
