hey guys,
Anyone who has any experience with wiring up indicators (the small orange ones in 400R bar) and park lights?
Just got car back with new motor and cant afford auto electrician so im going to to tackle it myself.
Car was in a smash and park lights have not been wired up since new head lights were fitted.
Help ? anyone?
maintenance or the general discussion areas. but oh well
hard to tell you how to wire it, since i cant see whats missing.
when i installed the blinkers in my 400r bar i cut the std Mspec lights plug of and wired into the new lights.. that way i could use the factory plugs to be able to unplug them when the bar comes off.
parkers, they are simply the smallest plug there.. it should be just a matter of putting the connection onto the back of the globe. once again. not enough info to tell you what needs to be done
yeah thanks man,
I got the parkers working. I couldnt find they passenger side factory plug anywhere that goes into the light, so i wired it from the drivers side and ran a wire across. A bit backyard but it works and the car doesnt know any different.
The blinkers in the front I just cut off factory plugs and crimped on some multi conectors (3 for the threee wires) and heat shrunk them all together and conected it up.
So its all done thanks anyway man. One thing after another with this car lately. I was thinking of selling it but just about everything has gone wrong with it lately so it should be reliable now hopefully. Wouldnt mind a gtr however.
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
