Yo!
I took my car for a run tonight with a mate who's practically a mechanic to see if he could figure out why my cars running so slow. Anyways the turbotech is set at 10-11psi but was spiking from 12 to even close to 15psi at times partiuclarly in 2nd gear, whenever it spiked to that amount my car would make this rapid muffled sort of backfiring noise and lose a huge amount of power..
My mate told me it's the boost cut... From what i know theres a restrictor in one of the hoses that connects to the turbotech, if the mechanics left that hose there and didnt take the restrictor out and just connected it to the turbotech would that be whats causing the problem? and is my mate right about that noise and power loss?
Cheers
Luke
https://www.sau.com.au/forums/topic/110872-boost-cut/
noise an power loss definately sounds like a (edited for SK :( ) : excess airflow protection
mine was caused by the air filter element falling out of the pod and the boost spiking to near 16 psi..
dont know what the turbotech is so im not sure what to say about the restrictor.
Edited by Craved
https://www.sau.com.au/forums/topic/110872-boost-cut/#findComment-2043712
oh i run a blitz ID3 so i never read that thread..
if your i doubt, run new hoses from the plenum/IC pipe to the controller, then new ones to the actuator..
no chance of a restrictor that way.
So there is a restrictor in the stock hoses? I'll do what you said though tomorrow :( maybe thats why my car wasn't pulling anything on the dyno...lets just hope the mechanics are hopeless in all respects and that thats the problem :yucky: i'll have to get a fresh dyno from elsewhere after i fix the boost cut problem, is there anything else that could cause a boost cut?
https://www.sau.com.au/forums/topic/110872-boost-cut/#findComment-2043763
Ah no, another recalcitrant;
Write it out 20 times..........
THERE IS NO SUCH THING AS BOOST CUT
Half way there……………
Hope you learnt a lesson, next time it will be detention for you.
:laugh: cheers :P
https://www.sau.com.au/forums/topic/110872-boost-cut/#findComment-2045315
Hey SK
I run KN flat filter ,Jaycar boost controller, threeand half cat back and my " protection" cuts real bad from 8-9 pounds how come half these guys dont get it till after 10? no fair!! if I keep it over 4000 through the gears its ok but from 2500 you would think someones turning the key on and off. I have an SAFC ( the blue one) shouldn't that fool the ECU into thinking the signals less and stop it?
https://www.sau.com.au/forums/topic/110872-boost-cut/#findComment-2052150
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
