  • Replies 164
12.6's....on the standard turbo, I bet you still get mugs trying to tell you you have a high flow. I remember the looks of disapointment people had when they looked under the bonnet of my old gtst. At least yours has some bling front mount and carbon bonnet for people to say 'ooh ahh' at in the lanes.
I don't suppose the drag racing bug has you looking at altered dragsters yet does it? There's a category for people the french foregin legion won't let in.
250 shot ready yet?
250 shot ready yet?
Yes, that's right.
Yes, sadly they do.
HongKongSpecial Intercooler but no CFRP on the car at all. The bonnet just has a vent in it.
Late-model, turbo, injected bikes w/out wheelie bars are the new outcasts. Injected/rotary/4/6cyl cars get 28 new comp brackets and they can't get one?!?! WTF?!?!
250hp shot? Hahaha.... Out of interest though, my car makes 255hp (190kW) @ the rears without nitrous and 355hp (265kW) with it. That's with the 100hp jetting. Funny that huh?!?!
Adrian
Yes 250rwhp and yet people with supposedly more (on a dyno) can't run that fast....
Perhaps the dyno should be used only as a tuning tool and not for a 'look at mine' sport.
I totally believe a stock turbo can produce eleventy billion horsepower on a dyno (actually I don't really care) it's just that in the real world cars drive on roads not rollers so getting the stock turbo to run 12's on the 1/4 in a street trim R33 whale seems far more interesting.
Edited by rev210
' date='27 Mar 2006, 10:09 AM' post='2050134']
incredibly sir
i was addressing the post above mine which suggested that our cars will all begin pinging at 13 psi....
Most agreeable then.
For a second there I thought you'd lost it.. :(
2rismo ran 12.6 with only 190kw at the rear wheels?
12.68 @ 107.09 mph - 1.78 60' - 3230lb race weight (me included obviously).
Plenty of other people have run 108mph but don't launch as well and therefore have slower ET's.
i just hit up the drags a few weeks back,
my car is an r33 with stock turbo (0.8bar of boost), hks-cat back, trust front pipe, stock dump, air filter + cai, fmic, ebc and coilovers. (car is kindof setup for drift, suspension wise, the rear was abit bumpy off the line and down the track)
and i was running
13.854 second
Terminal speed: 102.26mph / 165.15kph
Reaction Time: 0.230
60' - 2.261
330' - 5.983
660' - 9.038
660' Speed - 130.69kph
1000' - 11.643
i suck at launch thou, 2000,2500rpm :
' date='27 Mar 2006, 06:44 PM' post='2051684']
and i was running
13.854 second
60' - 2.261
330' - 5.983
660' - 9.038
1000' - 11.643
Like lots of people with R33's your car had money spent on various mods that made it actually slightly slower or didn't improve anything. I would have left the intercooler alone (it's a silly mod for a stock turbo anyway) and done the dump pipe.
I still maintain that you can take a pretty stock R33 gtst and make it generally faster with the factory intercooler than 99% of the fmic equiped cars going around. Give me an good aftermarket core for the side mount and the remaining 1% won't keep up over the 1/4mile either.
the good news is you can get it down to 13.6 or so pretty easy if you can drop 0.1 or so off the 60ft
I ran 13.8's with :
Stock turbo.
Stock intercooler
Turbo back exhaust.
pineapples
205 tyres.
consistant 13.4's with:
above
+ lightweight flywheel
Turbo 33's all have vvt and the s2 engines have a very similar turbo to the 34's(plastic front wheel).
My 289rwhp(stock turbo) took my car to a 12.7 @ 107 mph. It was a commodore ute but still weighed over 1400kg's..
Looks like the car hooked up ok off the line, you got another tenth or so there with that terminal.
What diff ratio and gearbox did you have?
My R33 is making 265hp with full 3" exhaust, air filter and safc at stock boost (9psi)
I've run a 13.4@105mph, 2.18 60'.
Hoping for 12s with fmic and power fc soon...
If your keeping the stock turbo for this attempt you don't need a fmic at all to do the time. Power FC is a good bet though.
I ran 13.8's with :
Stock turbo.
Stock intercooler
Turbo back exhaust.
pineapples
205 tyres.
above
Hey rev210,
Having an auto R33 and not doing over the top mods, what sort of time should one get? and if you don't mind could you list some mods that would help or you recommend? I've seen that you said you had pineapples on, sorry I'm not familiar with what they are (I know it's for better traction) , is it anything major and would effect everyday driving etc?
What I've don so far to it:
3" turbo back exhaust
POD (making an enclosed shield for it)
Stock intercooler
Bigger turbo (not boosted yet)
Cheers!
had mine dynoed at hyper drive (r33 s2)
it's stock turbs with fmic,pob filter,3" dump and zorst std boost setting
did 256rwhp, lumpy said that was alittle high but normal enough
Edited by stR33ter
    • https://www.efisolutions.com.au/coolant-temperature-sensor-bosch-180sx-s14-s15-r33?gad_source=1&gclid=CjwKCAjwzMi_BhACEiwAX4YZUHsCQhbiDT_NC3q5wD9jrzH6Dts9eGSr19NXSDw7x9WVm1sH7G3S4hoCwaUQAvD_BwE this is the one i replaced today
    • I have replaced the larger coolant temp sensor, i do see a smaller one next to it (looks to be just 1 pin) but i assume that is just for the dash? or should i replace that aswell?
    • Check coolant temp sensor ~ symptoms fit the hard hot start/cold start OK scenario --- if sensor goes open circuit, ECU thinks engine is cold and enriches mixture ....works when engine cold, but floods them with rich mixture when hot (Hyundi MAP engines are a bit infamous for this)...
    • OK, starter changed for a spare without much trouble. Neil had kindly left space to get to the top starter motor bolt from above with a long spanner which makes the whole deal much easier, and everything else was neat and easy to get at from underneath. Once the starter was changed everything was good, unplugged the CAS and turned the motor on the starter to make sure everything was free and happy. Onto properly priming the oil and first start. I'd picked up one of these oil prime kit from Boost doc a while back and this was my first time using it.  https://boostdoc.com.au/products/engine-oil-prime-kit?_pos=1&_sid=28c628a65&_ss=r While I'd organised all the fittings to hook it up to my GTR (sump plug to -6 feed and -4 T to tap it in and retain the oil pressure gauge, neither suited on this car as the oil pressure needs to T into 1/8 NPT not -4 and the Aeropro sump has some massive drainplug not that factory whatever it is. So, waiting for a couple of fittings, then I'll prime it and do first start, hopefully next weekend. Other than that going well, there is very little stopping a final alignment, tune then shakedown day
    • Also to mention, i just tested the CAS, seems to be working fine, can hear the pulses inbetween 0 and 180 degrees, another mention aswell, when i let the car sit for about a hour today, i went to start it and it almost fired on first crank, then just completely struggled. Could it possibly be blocked injectors?, maybe allowing a little bit of fuel to seep past allowing it it almost start first crank?
