  • Replies 164
Ceramic wheel in there.Dump raised boost to 15.5psi thru the mid and 12 from 6200 up so we dropped it back to 12.5 thru the mid with boost falling to 11psi thru the top as Skylines do.
Better mid power but no different up top. Power 299.1rwhp @ 11-1 afr still going over 300 @12-1 but the topend timing hits 22deg from 6500rpm being the reason it picks up 10-15hp but we dont want that much timing so its time for an ECU because we all know leaning out an SAFC also adds timing.
Dont know why this car is better than average but the owner says its quicker than other more modifyed R33s and i spose thats more of a test than a Dyno run.
Who cares about dyno figures. Take it to the track, if it runs the MPH consistant with that power, then you know for sure it's a freaker.
Until then, its just another dyno figure from a single source.
but the raw power of a dyno printout is awesome!!!!!!
....then the x-man spun round and with his mighty hand he shoved the dyno printout in the face of his enemy!
Stuck by the awesome power of it's reflex paper cheapness the enemy was blown backwards through the air to land 10 feet away in a crumpled heap.
AMAZING!
' date='5 Apr 2006, 02:39 AM' post='2072085']
It is true this is the only dyno the car has been on, but for years it has been whoppin my R33's arse... exact same mods yet always pulls away....I am sure I was even running more boost!!. It is the same with heaps of other modified R33's out there. Cruises, on the way home from a car show whatever, always pulls away. You really need to ride/drive it and you can feel that it pulls harder than a similar modded R33.
I am sure he would chuck it on another dyno --- your shout of course :laugh:
http://image-cache.skylinesaustralia.com/f...-1143205919.jpg
well to prove that my one is truthful here is the dyno sheet!!! 302rwhp!!!
To bring back an old post.
That dyno graph has intake temp of 53 deg and ambient of 25 thats a large spread and will increase the HP reading noticably. Thats almost a full 30 degree increase.
Yes it does thats the point.
Shootout takes the ambient temp and adds a correction based on the inlet temp. To try and give a consistent reading taking away temperature variables. So on a different temp day you get the same HP reading.
So a large gap between the two numbers means the dyno will add Correction IE adding HP.
Well actually that was my dyno graph...which is totally different to the car they are talking about right now!!!
If an airfilter has 30deg higher than ambiant then we still have to put the probe at the filter,its in the guidelines.HIPSI can check the temp difference on this car but i think its about 16deg.Wildcats cars 300rwhp was backed up on another dyno (Hyperdrive i think)
My Dyno seems to be one of the lowest reading at the moment with an average of 8 to 10% less than Xspeed and Hyperdrives Shootout graphs so im getting it checked as Dyno dynamics are in town for the show this weekend.Ill post the result.
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
