  • Replies 164
I pulled 242rwhp with only a pod and 3' exhaust out of the turbo in an auto with the rb2.5t on psi s dyno in perth
then had a front mount and eboost and did 244rwhp at 8 psi and then 250 at 10psi on xspeeds dyno
both places said they had never seen an auto pull that much with thous mods only
james
Ignition system seems to play a part in the power differences perhaps.
I notice that many of the curves are similar on 240/50rwhp cars to the 300ish ones, with the difference coming in up top. If the spark isn't as clean this could account for the power difference. The coils and wires under the cover get very very hot and this effects resistance and reduces the efficiency of wires over time with heat cycling.
no way r33's can make that much power.
the above poster is claiming 267.2rwhp on stock boost stock turbo, HELLO THATS IMPOSSIBLE.
r34 gtts with running 12-14psi with powercf, hi flow exhaust etc etc are only making 260-270HP on the stock turbo.
Edited by noise
I am pretty sure that 25 neo's can only do 195-205rwkw max from stock turbo.
Thats 261.50-274.90rwhp.
how is an older less powerfull rb25 going to put out more power with fewer mods?
it isnt, stop talking shit.
or point me in the direction of threads of people posting dyno sheets to show otherwise.
i dont know why yours didnt make more then 270 rwhp
Shall I direct you to threads showing you this? how about you go to a workshop with a database of dyno sheets and look at them?
I didnt even own the car when it made the power, so i have no need whatsoever to talk it up. Those numbers where made on a DD accredited dyno
The car had
A garrett cooler, not gtr sized, just under.
A mettams morley dump and front, leading into a apexi cat back. 3 inch hi flow cat
11 psi
Walbro fuel pump
KN air filter
s2 motor
manual
standard timing
272 rwhp.
www.antilag.com/personal/tom/my31 for pics of the engine bay etc, so you can see it wasnt packing a hidden t88 etc.
tj
and back to the argument ... 319 rwhp is very very very hard to believe
Edited by dan_the_man
umm ok...
im not saying 319rwhp is possable...
but why have many not just one or two, rb25 run between 280-300rwhp on stock turbo?
just because ur r34 didnt make it, doesnt mean its not possable for another rb25 power cars to do it
james
Hey James! man hows that happening? I only got 202rwhp with 3" exhaust & POD! Damn I'm pisst! What PSI was it at b4 FMIC etc?
Back to the basics,Im sure there not stock but they sure look untouched.
NEO engines have nastie combustion chambers for polution reasons and will ping at less timing than an R33 RB25.
Some shops are not aware the NEO head is different,A few weeks ago a shop removed the head of a NEO fitted to an R33 finding it looked different told the guy the head was an NA head and had to be replaced.
So yes theres lots of misinformation around.
Some strange things have happend to new cars like in the early 70s Fords GTHO Phase 4 was shelved by the government (AS were GM etc)
so ford stuck some parts on a 2 door falcon and tagged it RPO87
the rest ended up in ZF Fairlanes without the new owners ever knowing
and over the years we saw stockers with Noddy iron 9in diffs winged sumps and 4V heads with 780cfm Carbs etc so who knows what may have happened with these cars,Prolly modded very early in life by very carefull mechanics?
got to remember that the dyno is a tuning aid at the end of the day. There is some value in relative comparisons but, not something people need to get hung up on if their car is doing what they want on the road or track. If your tuner is handing the car back to you with improved power characteristics this is what matters.
Some R33 gtst 200rwkw+ cars have run against my old R33 gtst (dyno of 170rwkw) and had an ass whipping both in 1/4 mile time and terminal speed.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
