I am pretty sure that 25 neo's can only do 195-205rwkw max from stock turbo.
Thats 261.50-274.90rwhp.
how is an older less powerfull rb25 going to put out more power with fewer mods?
it isnt, stop talking shit.
or point me in the direction of threads of people posting dyno sheets to show otherwise.
well to prove that my one is truthful here is the dyno sheet!!! 302rwhp!!!
Edited by Wildcat
  • Replies 164
here's a standard turbo running 7psi , standard spec rebuilt motor with a HKS 264 deg exhaust cam set at '0' deg. It has a S-afc and factory ecu, large bosch fuel pump (from when the motor ran nitrous). Runs a turbo back exhaust and factory intercooler.
The rich mixtures are due to the fact that I was selling it to someone and I wanted it to be reliable from the get go. He was also not yet used to the power so the very mild tune was to keep him alive long enough to allow him to re-tune.
The change to the exhaust cam took away the 'bump' even without the ecu upgrade.
This car wherever it is could easily be tuned to run walk in the park high 12's even without a decent launch.
Another example of how good the factory turbo is can be found in 2rismo's car, even without my old nitrous kit he was able to run into the 12's. With the kit switched on he runs 11's.
Pulp i dont know how it pulled that much
1st run Mods 3, mandral bent exhaust from turbo back and hfc
cypher pod fillter
Psi in wangara first run 242rwhp 10 psi
they spun out there was another customer there and he said i was pulling more than his r33 and he had piggy back ecu and frontmount + my mods and it was manual
2nd xspeed after front mount and eboost 240rwhp at 8psi and then 250 and 10psi
i told them about psi effort and they said psis dyno would have been stuffed then my baby busted out the 250rwhp
the turbo looks stock and i have not touched the it but i was told it MUST have been hiflowed to pull that power
i have all ways kept it serviced by the same mechanic
james
Edited by Miller the hoon
That dyno printout that Wildcat posted is of my car..... And as far as we are aware its still got the stock ECU, with just the piggy backed AVC-R to control the boost and a SAFC-II to control air/fuel mixtures... the timing and air/fuel was played around with and at some times the curve did smooth out a bit but it cost HP up the top end.... The curve might not look as smooth as the other one you posted but I dont find it a problem at all when driving....
its one thing to be able to make the power its another not to have too much knock and blow shit up in the car.. my r34 gtt made 297rwhp but had to be put a lil down to 268hp cuz my engin was knockin way too much and i have a very hevy foot.plus i would hait not to have a reliable car.. but gettin 319 outa a stock r33 sounds very sus as i have got a 3.5inch exohst all the way, fule regulator, pfc, ebc, pot filter,fmic and a few more mods to be able to make that power but i still need engin internals to be able to take push it a lil more.. i cant picture how a gtst r33 can make more than an r34 with less mods!! and the r34s have Veriable Valve timeing too wich should add some edge.. i agree with noise. newer car means better engin although the ciramic turbo in the r34s limts us to max of 15psi our engins start knockin alot at about 13psi with 98octane fule that is how ever the car u guys were talkin about doesnt have a pfc do u probebly dont know howmuch knockin u gettin unless ur usein a dig tool for it..
s2 33 has vvt also, not sure if s1 do.
friends ex r33 made well over 350 rwhp on stock internals, and for more then a week. 320 is a walk in the park.
13psi causes me motor to knock does it? is that 13 psi with a stock turbo? a gt30r? t88? because they all flow the equal same amount of air at 13psi....
a stock 34 turbo is out of puff before a 33 one. dont forget that.
dude if your engines start knocking at only 13 psi something is very wrong hey and as long as they're tuned right, the stock rb's can make very decent hp on standard internals
if i had those mods and i had knocking at 13psi i'd fire my tuner asap
' date='24 Mar 2006, 10:49 AM' post='2044831']
No way in hell its making that sort of power with totally stock bits
cams, headwork ?
maybe more capacity ?
what sort of correction on the dyno?
is the dyno currently dyno dynamics accredited?
No Cams or headwork that we know of. Definitly standard capacity as NIB said the car looks like it has never been touched.
Has been running with the stated mods for more than 2years now at the same boost level and never had any engine troubles so reliable??? HELL YEAH... I guess we can all just say that this car is just a freak or posible hi flow turbo?? We wont know until we pull it apart I guess...
' date='26 Mar 2006, 07:41 PM' post='2048856']
2rismo uses nos to make his power :thumbsup: CHEATER! :D
What time has this 33 set with 320 (sAfrican American) rwhp
thats got to be mid 12 with good mph....
runs 12's without nitrous tho' on the stocker turbo.......
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
