  • Replies 164
12.6's....on the standard turbo, I bet you still get mugs trying to tell you you have a high flow. I remember the looks of disapointment people had when they looked under the bonnet of my old gtst. At least yours has some bling front mount and carbon bonnet for people to say 'ooh ahh' at in the lanes.
I don't suppose the drag racing bug has you looking at altered dragsters yet does it? There's a category for people the french foregin legion won't let in.
250 shot ready yet?
250 shot ready yet?
Yes, that's right.
Yes, sadly they do.
HongKongSpecial Intercooler but no CFRP on the car at all. The bonnet just has a vent in it.
Late-model, turbo, injected bikes w/out wheelie bars are the new outcasts. Injected/rotary/4/6cyl cars get 28 new comp brackets and they can't get one?!?! WTF?!?!
250hp shot? Hahaha.... Out of interest though, my car makes 255hp (190kW) @ the rears without nitrous and 355hp (265kW) with it. That's with the 100hp jetting. Funny that huh?!?!
Adrian
Yes 250rwhp and yet people with supposedly more (on a dyno) can't run that fast....
Perhaps the dyno should be used only as a tuning tool and not for a 'look at mine' sport.
I totally believe a stock turbo can produce eleventy billion horsepower on a dyno (actually I don't really care) it's just that in the real world cars drive on roads not rollers so getting the stock turbo to run 12's on the 1/4 in a street trim R33 whale seems far more interesting.
Edited by rev210
' date='27 Mar 2006, 10:09 AM' post='2050134']
incredibly sir
i was addressing the post above mine which suggested that our cars will all begin pinging at 13 psi....
Most agreeable then.
For a second there I thought you'd lost it.. :(
2rismo ran 12.6 with only 190kw at the rear wheels?
12.68 @ 107.09 mph - 1.78 60' - 3230lb race weight (me included obviously).
Plenty of other people have run 108mph but don't launch as well and therefore have slower ET's.
i just hit up the drags a few weeks back,
my car is an r33 with stock turbo (0.8bar of boost), hks-cat back, trust front pipe, stock dump, air filter + cai, fmic, ebc and coilovers. (car is kindof setup for drift, suspension wise, the rear was abit bumpy off the line and down the track)
and i was running
13.854 second
Terminal speed: 102.26mph / 165.15kph
Reaction Time: 0.230
60' - 2.261
330' - 5.983
660' - 9.038
660' Speed - 130.69kph
1000' - 11.643
i suck at launch thou, 2000,2500rpm :
' date='27 Mar 2006, 06:44 PM' post='2051684']
and i was running
13.854 second
60' - 2.261
330' - 5.983
660' - 9.038
1000' - 11.643
Like lots of people with R33's your car had money spent on various mods that made it actually slightly slower or didn't improve anything. I would have left the intercooler alone (it's a silly mod for a stock turbo anyway) and done the dump pipe.
I still maintain that you can take a pretty stock R33 gtst and make it generally faster with the factory intercooler than 99% of the fmic equiped cars going around. Give me an good aftermarket core for the side mount and the remaining 1% won't keep up over the 1/4mile either.
the good news is you can get it down to 13.6 or so pretty easy if you can drop 0.1 or so off the 60ft
I ran 13.8's with :
Stock turbo.
Stock intercooler
Turbo back exhaust.
pineapples
205 tyres.
consistant 13.4's with:
above
+ lightweight flywheel
Turbo 33's all have vvt and the s2 engines have a very similar turbo to the 34's(plastic front wheel).
My 289rwhp(stock turbo) took my car to a 12.7 @ 107 mph. It was a commodore ute but still weighed over 1400kg's..
Looks like the car hooked up ok off the line, you got another tenth or so there with that terminal.
What diff ratio and gearbox did you have?
My R33 is making 265hp with full 3" exhaust, air filter and safc at stock boost (9psi)
I've run a 13.4@105mph, 2.18 60'.
Hoping for 12s with fmic and power fc soon...
If your keeping the stock turbo for this attempt you don't need a fmic at all to do the time. Power FC is a good bet though.
I ran 13.8's with :
Stock turbo.
Stock intercooler
Turbo back exhaust.
pineapples
205 tyres.
above
Hey rev210,
Having an auto R33 and not doing over the top mods, what sort of time should one get? and if you don't mind could you list some mods that would help or you recommend? I've seen that you said you had pineapples on, sorry I'm not familiar with what they are (I know it's for better traction) , is it anything major and would effect everyday driving etc?
What I've don so far to it:
3" turbo back exhaust
POD (making an enclosed shield for it)
Stock intercooler
Bigger turbo (not boosted yet)
Cheers!
had mine dynoed at hyper drive (r33 s2)
it's stock turbs with fmic,pob filter,3" dump and zorst std boost setting
did 256rwhp, lumpy said that was alittle high but normal enough
Edited by stR33ter
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
