im australian.
I used to go to clubs 2 times a week in aus. They are 100000 times better here. No drunken fights. everyones there just to have a good time a little expensive (cover charge usually 3000円 / 4000円 $36/$48). People buy you drinks. you can talk to girls and they are mostly genuinely interested in talking.. etc etc heaps better. And from spring time to the end of summer there are huge dance parties a few times a week.
Japan is famous for its car culture but the trance scene is even bigger. :O
ps sorry for the hiijack
pics are a bit big
akeenan...looks awesome mate, Stacey and I are keen trancers and love a good rave...we are planning to come over soon and would love some info on where to go etc...
back on topic....have not been out in Melb for a few years but Zos (sp*) 161 the Viper room etc were all to our taste....had a ball.
https://www.sau.com.au/forums/topic/110893-clubbing/page/2/#findComment-2047892
WTF is a cookie monster?
haha well... when smackies go out they take pills (bikkies) but theres nothing funny about a bikkies right? bikkies (or biscuit's) and cookies are essentially the same thing so if you call someone a "cooki monster" its becaues they power down the cookies like the monster of Seseme Street!!
before any of you tiprats accuse me of knowing a little too much about this stuff ill make it clear that i've never taken drugs or even smoked a ciggi... i fcken hate smackies
https://www.sau.com.au/forums/topic/110893-clubbing/page/2/#findComment-2049170
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
