SOLD
I've got an as-new Alpine head unit for sale. It came in my car when I bought it but I swapped it out for my trusty old head unit which I love and know so well I can control without even thinking or looking :laugh:
Here are the specs from the Alpine site:
CDA-9853R Bass Engine Pro CD / MP3 / WMA Receiver / Changer Controller
This high-class head unit is extremely powerful and sophisticated. It features Alpine’s unrivaled Bass Engine Pro sound tuning, including 6-channel digital time correction and 5-band parametric equalizer.
50W x 4 High Power Amplifier
MP3/WMA Playback
MP3 ID3 Tag Display
i-Personalize
Bass Engine Pro
6 Position Digital Crossover
6-ch Adjustable Digital Time Correction
3 PreOuts
'05 Amplifier Link Ready
Ready for iPod
Vehicle Display Interface Ready
Multicolor Illumination
Remote Control
Max Tune SQ Tuner
5-Band Digital Parametric Equalizer
RDS Radio Data Display
Retail is $700, I'm after $250 or very near offer. Works perfectly, looks like the previous owner had only installed it recently, as the box was in the boot, with the instructions and the case to hold the removable faceplate. Works perfectly, had a brief play with it while I had it in the car. I read up on it after swapping it and thought maybe I should have left it in there, but I can't be a$$ed opening up the dash etc again. :P Oops.
Send me a PM on here or an email (preferable) via my Profile. I can deliver it to ur door if u like. Cash makes the world go round.
Edited by sl33py
why do people have to haggle? No matter what the price!
$50?
because there's a certain limit as to how much money i want to spend on things.
unlike yourself, i don't pour a good percentage of my paycheck into my car, i'm a full time university student with a casual job, with certain investments.
that good enough reason for you mate?
Why do people always add "mate" when they are pissed off? :D
I wasnt actually refering to your haggle of $50
I was making an offer on the CD player! My offer was $50.
You see I was trying to make funny?
Anyways as soon as I read it back I realised that it looked like i was abusing your bid and that is not what i had in mind!
My apologies for the misunderstanding. Original post edited!
oh and yes I do pour lots of money in to my car, thanks for noticing :P
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
