Had a look at a '96 s2 r33 today. Just wanted to clarify a few things...
the vin on the firewall was ECR33-102113
build plate engine number RB25DET 2498
build plate chassis F55R30A RC41
Model number GGKBRTFR33UDA-A-AA
then i had a look at the import approval on the strut tower
Approval number 13993
04/01
VIN 6T91MPR04T1JPL005
i cant remember what the rego sticker said, sorry.
Now am i missing something or should the import approval vin match the one on the firewall? or the model no on the build plate?
also with the blue build plate i read on the forums that it should be smooth, but the one i looked at had been stamped, or engraved, i could feel the ridges to each number. is this right?
I know that some of the imports get the km wound back and i think this did as well as the odo showed 56K km but there was a sticker on the cam cover that said its 100Kkm service was at 124Kkm on 04/01. i dont really expect a car to do less then 5Kkm a year, even a import.
and another thing that was a bit dodgy was that the radiator water was a bit murky, brown like. sort of rusty or something. this doesnt look like a good sign to me. it should be green or something. he said that the car did have a front mount on it but he took it off after a car with a tow ball reveresed into the skyline. he said that the tow ball protruded into the air gap in the front bar and damaged only the intercooler so the stock one has been placed back on it. i sort of think that it may of damaged a bit more then that???
But on the plus side, it was my first drive of a skyline and i was impressed. the car drove really well with the lowered suspension. the boost came on strong and early although the original boost gauge was not working, the bov was a little annoying. the car looked tops with 350z 18s on it. i didnt even know that they fitted straight on, bolt on? one problem was i was slowing down from a half decent speed and the brakes locked up. i didnt mean for them too (but it was good in a way)-i didnt even think i was slowing real hard, but a great big puff of smoke came from the front wheels and i didnt feel the abs. dont all s2 have abs? anyway im pretty impressed with it and will continue on my endevour to find one that feels right. at least it is a good base for other cars.
any help with the issues raised would be great
Edited by lastlineofdefence
https://www.sau.com.au/forums/topic/110942-r33-for-sale-question/
Sounds liike it was imported pre-SEVS, the Australian VIN wasn't just ECR33XXX with a prefix before it (eg 6U90001ECR33XXX). If you are concerned you can contact DOTARS directly to find out the details of importation.
Blue build plate: engraved is fine. Read this thread for more info.
http://www.skylinesaustralia.com/forums/in...howtopic=110196
ABS optional. My S2 does not have it.
Coolant can be other colours but should be clean, indicating it's been changed regularly. Rusty sounds like hasn't been changed as often as it should.
I'd go with the timing belt sticker for kms. Either wound back or been swapped with a different dash cluster (maybe not hooked up right that's why boost gauge isn't working??)
Bottom line is that car has been wound back - probably has 160k on it if going by timing belt sticker..If you still like the car use this as bargaining tool...most of the r33s are wound back anyway.
ABS - you can see the module on the passenger side of firewall if it has it. Check if it has an airbag - I think most series2 do. If it has an aftermarket wheel this is illegal.
and back on topic.
Sorry i need the help.
private sale, sir-d
You have to run a few checks on it then with Nissan Fast software as well as get a police check and then get a mechanic to look it over... i went to a dodgy car dealer, found a car i liked, the car was a mess even after 2 RACV inspections. I refused to buy it. Went to a GOOD dealer and now have a massive smile on my face when I drive it!
why does everyone say the clocks have been wound back... they wouldnt do it to every single car... plus they sell and get a new car coz there cheap as chips
Mate they pretty much all are unless you have logs books. I have a friend who knows an importer and he asked if he wanted the k's wound back on his but he opted not to because he had all the orginal log books for it. it was not much over 100k but as someone else has stated cars with less are more attractive.
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
