turbo timer
Andrew, It is possible to get a relay which allows you to lock the car with the engine still running, a few of the car audio places do it from memory. I just don't think they are necessary, but if your getting one done then I like the look of the Apexi one, small and unobtrusive.
See'ya:burnout:
https://www.sau.com.au/forums/topic/11097-turbo-timer/#findComment-183808
If you are doing moderate driving then you don't need to cool down the car at all, that's my point. If you thrash it then leave the engine running for about 2 mins. The best way is when your about 5 mins away from your destination, drive normally and the car will cool down by itself.
See'ya:burnout:
https://www.sau.com.au/forums/topic/11097-turbo-timer/#findComment-183939
Originally posted by Nizmo
Andrew check your insurance policy too because some insurce policies are void if you attach a turbo timer to your car because of the risks of it left running after an accident.
for that exact reason i thought they were illegal.. when you turn the key off, the car is suppose to turn off.
Shaun
https://www.sau.com.au/forums/topic/11097-turbo-timer/#findComment-185324
Yes, I agree.
Turbo timers are a waste. Are only handy if you want to let it cool down by its self and you don't want to wait around.
I have a HKS type 1, that measures your speed, 1/4 times, rpm warning, rarara list goes on. I can sell it for $300 including delivering and harness. Never opened, if anyone wants it.
https://www.sau.com.au/forums/topic/11097-turbo-timer/#findComment-187527
Most people with turbo timer's end up switching them off cause they don't want to wait while there car cools down enough to lock the car. If your racing then just leave the engine running long enough to take some of the sting out of the oil temp, other than that don't worry about it.
See'ya:burnout:
https://www.sau.com.au/forums/topic/11097-turbo-timer/#findComment-187714
Don't know about you guys, but i couldn't live without my turbo timer... I always leave the car running, even if its a casual drive down to the shops... My alarm work fine with the turbo timer... I switch the car off, press the button and she locks and then when the car switches off its immobilised...
In the mornings i use it to warm up the car... I start the car, turn the key off and set the turbo timer for 5:00 mins, lock the car and go back inside to finish getting ready... I'm no Captain Cold-Cane... :)
https://www.sau.com.au/forums/topic/11097-turbo-timer/#findComment-188087
In the mornings i use it to warm up the car...  I start the car, turn the key off and set the turbo timer for 5:00 mins, lock the car and go back inside to finish getting ready...  I'm no Captain Cold-Cane...  :P
i do the same thing would be lost without it , i didnt have a problem with the timer and getting insurance
https://www.sau.com.au/forums/topic/11097-turbo-timer/#findComment-193404
I've got one of the cyclops alarms that will allow the turbo timer to run while I activate the alarm system. It locks the doors when I press the button and as soon as the car stops running the immobilisor arms within 10 seconds. Even with a non thrashing drive for 15 mins to the shops and back with the air con on the timer reads at least 50 seconds to run... so I think they are worthwhile.
https://www.sau.com.au/forums/topic/11097-turbo-timer/#findComment-193488
Are you able to find out what wire they cut?
They want to sell me a... "HKS Keylock release adapter"
for "..A$96 delivered to you"
Originally posted by GTS-t VSPEC
I think there is a solenod which stops you with drawing the key while the engine is going. Most places which install turbo timers cut one of the wires to prevent this happening.
See'ya:burnout:
https://www.sau.com.au/forums/topic/11097-turbo-timer/#findComment-196377
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
