im really going to regret this =[
1993 180SX WITH A SILVIA FACE LIFT
93XXX
SUNROOF
MANUAL
REGO TILL NOVEMBER
3"ZORT FROM TURBO ALL THE WAY
FRONT MOUNT INTERCOOLER WITH SHINY PIPESoOoOo
GREDDY PROFEC B II BOOST CONTROLLER
WALBRO FUEL PUMP
FUEL REGULATOR
S15 INJECTORS
OIL CATCH CAN
AIR FILTER
TIEN HA COILOVERS ALL ROUND
FRONT AND REAR STRUT BRACE
DRIFT BUTTON
AFTERMARKET STEERING WHEEL
BUCKET SEAT (NOT FITTED)
VERTEX KIT ALL ROUND
16" WEDS SPORTS RACING RIMS
i have never taken this car for granted, i have alwas taken extreme care when it comes to this car, never park it newhere i cant see it, i always get my car serviced every 5000 or close to it, by a reputable mechanic he is also a member on this forum and x sponsor myhiep. Anyone who knows me knows i dont take this car out on the weekends, the car has never been defected *fingers crossed* it wont happen. For about 6 months last year the car was off the road due to s15 front conversion, how ever it didnt happen soo it was a shame.
Engine wise the engine is in tip top condition, i had my engine replaced about 2 year back when it blew on me =[ the engine that replaced it had low km's 50 thou and since then i have driven it maximum 20 thou, i only drive this car to and from work,. I have taken it to the track only once. ill be servicing it beginning on next month if not sold. i hardly ever boost the car past 11 psi, 95% of the time the EBC is switched off
Body wise, ill be honest it needs a spray currently in matt black, looks quite tough i must say, but the body is very straight and stiff when i lift the front of the car with a jack after certain point the rear starts to raise, there are no dents on it what so ever, at the moment the bonnet is black, it creates a sort of drift look.
im looking for 13,000 ono, i realise its a bit much for a car with not that much mods, but my car is much loved and well taken care of be nice =]
will trade for a r32 gtst, would prefer sydney buyers. 0423281569 after 9am and before 12am
http://i21.photobucket.com/albums/b262/mind_circus/Front.jpg
http://i21.photobucket.com/albums/b262/mind_circus/side.jpg
http://i21.photobucket.com/albums/b262/mind_circus/back.jpg
https://www.sau.com.au/forums/topic/110972-sil80-turbo-sydney/
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
