im really going to regret this =[
1993 180SX WITH A SILVIA FACE LIFT
93XXX
SUNROOF
MANUAL
REGO TILL NOVEMBER
3"ZORT FROM TURBO ALL THE WAY
FRONT MOUNT INTERCOOLER WITH SHINY PIPESoOoOo
GREDDY PROFEC B II BOOST CONTROLLER
WALBRO FUEL PUMP
FUEL REGULATOR
S15 INJECTORS
OIL CATCH CAN
AIR FILTER
TIEN HA COILOVERS ALL ROUND
FRONT AND REAR STRUT BRACE
DRIFT BUTTON
AFTERMARKET STEERING WHEEL
BUCKET SEAT (NOT FITTED)
VERTEX KIT ALL ROUND
16" WEDS SPORTS RACING RIMS
i have never taken this car for granted, i have alwas taken extreme care when it comes to this car, never park it newhere i cant see it, i always get my car serviced every 5000 or close to it, by a reputable mechanic he is also a member on this forum and x sponsor myhiep. Anyone who knows me knows i dont take this car out on the weekends, the car has never been defected *fingers crossed* it wont happen. For about 6 months last year the car was off the road due to s15 front conversion, how ever it didnt happen soo it was a shame.
Engine wise the engine is in tip top condition, i had my engine replaced about 2 year back when it blew on me =[ the engine that replaced it had low km's 50 thou and since then i have driven it maximum 20 thou, i only drive this car to and from work,. I have taken it to the track only once. ill be servicing it beginning on next month if not sold. i hardly ever boost the car past 11 psi, 95% of the time the EBC is switched off
Body wise, ill be honest it needs a spray currently in matt black, looks quite tough i must say, but the body is very straight and stiff when i lift the front of the car with a jack after certain point the rear starts to raise, there are no dents on it what so ever, at the moment the bonnet is black, it creates a sort of drift look.
im looking for 13,000 ono, i realise its a bit much for a car with not that much mods, but my car is much loved and well taken care of be nice =]
will trade for a r32 gtst, would prefer sydney buyers. 0423281569 after 9am and before 12am
http://i21.photobucket.com/albums/b262/mind_circus/Front.jpg
http://i21.photobucket.com/albums/b262/mind_circus/side.jpg
http://i21.photobucket.com/albums/b262/mind_circus/back.jpg
https://www.sau.com.au/forums/topic/110972-sil80-turbo-sydney/
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
