123456 Posted March 25, 2006 Share Posted March 25, 2006 hey i recently bought a 1990 skyline r32 gts-t and im trying to service the thing but unfortunately it didnt come with a service manual of any type. i was hoping you guys could help me out with a few questions How much oil does it take? (as in how much to put in after ive drained the old stuff out) What are the spark plug gaps? Link to comment https://www.sau.com.au/forums/topic/111003-r32-gts-t-generaly-maintenance-questions/ Share on other sites More sharing options...
MerlinTheHapyPig Posted March 25, 2006 Share Posted March 25, 2006 can't remember spark plug gaps off the top of my head it takes a bit under 4 litres of oil from memory. Just stick 3 litres in, and keep adding until you get somewhere between E and F on the dipstick (btw, there is 1 litre of oil between E and F), then start the motor for 30 seconds or so, turn it off, let it sit for 10 mins and top it up to F. Link to comment https://www.sau.com.au/forums/topic/111003-r32-gts-t-generaly-maintenance-questions/#findComment-2047789 Share on other sites More sharing options...
WazR32GTSt Posted March 26, 2006 Share Posted March 26, 2006 4.2L oil from memory spark plugs: BCPR6ES-11 (1.1mm) or BCPR6ES (0.8mm) you can get 1.1mm gap if you are running around stock boost if you are running 12psi+ go for the BCPR6ES the are NGK coppers good luck with the service Link to comment https://www.sau.com.au/forums/topic/111003-r32-gts-t-generaly-maintenance-questions/#findComment-2049252 Share on other sites More sharing options...
joh21m Posted March 28, 2006 Share Posted March 28, 2006 (edited) This is what i use and it seems to be working A.O.K: Oil: Motul Turbolight 4100 Oil Filter: Cooper Z145A Fuel Filter: Ryco Z201 Plugs: NGK BCPR6ES Edited March 28, 2006 by joh21m Link to comment https://www.sau.com.au/forums/topic/111003-r32-gts-t-generaly-maintenance-questions/#findComment-2055467 Share on other sites More sharing options...
Cubes Posted March 28, 2006 Share Posted March 28, 2006 The two used filters I compared (chopped up) I would have a cooper over a ryco. The ryco looked as if some of the pletes blew out, if that makes sense, not blow out as in dissapear but a few had wide spaces between the pleates while others were very closely packed. Basically this is how I would rate oil filters. Nissan Purolator PureOne Purolator Premium K&N Cooper Ryco I havent chopped up a genuine nissan filter yet.. But will do soon to check it out. Link to comment https://www.sau.com.au/forums/topic/111003-r32-gts-t-generaly-maintenance-questions/#findComment-2055580 Share on other sites More sharing options...
