  • Replies 112
yeah, i have an fcon pro v at home gathering dust!! came with the car, impossible to tune in melbourne.
Which really sucks coz they are a fantastic ecu, 32x32 mappings and heaps of features.... had to downgrade to a powerfc :D
Edited by MerlinTheHapyPig
Guest Mashrock
BD4s is the only licensed tuner in Australia.
CRD borrows the software from BD4s when they tune.
ah i knew it was in some mess like that.
who is actually good for tuning these computers??
as there is no way i'm putting in a power fc.
and how does this guy access his fcon files off the computer? can i link it to a laptop etc??
needs to know.
actually, without getting into some sort of argument here on powerfc vs other ecu's
Im not such a fan of powerfc's either, whilst they have their advantages in being a plug-in replacement ecu, they also aren't very flexible. and only have 20x20 mapping... (compared with wolf 3d v4 for example which has 16 load points and rpm points every 125rpm (which between 0-8000rpm equates to 64 points eg. 16x64 point mapping...)
Also i don't think power fc's can control additional injectors, thermofans, aux outputs, etc...
BD4s aren't too bad price and they are pretty proficient tuners (they also do other ones eg PFC). My brother's car came ex-Japan with an FConV which we got Yoshi to tune up.
Only reasons we switched to a PFC:
- BD4s is too far from us
- Piggyback vs standalone (plus someone stole the FCon :( )
Apples and oranges comparison. The Power FC uses the AFM as its primary load source, so it has very fast and accurate details on the actual airflow going into the engine. The Wolf uses a MAP sensor as its primary load source, which of course is useless once the max boost is achieved and held. So it NEEDS more loads points to make up for its deficiency in load sensing.
Looking at it another way, the Power FC arguably has more USEABLE load points. Because the AFM is showing changes in airflow while the MAP sensor is showing no change in manifold pressure. All the Wolf has is RPM changes, that’s one dimensional tuning. If max boost is achieved at 5,000 rpm, it could easily end up with only 20 X 1 (= 20) load points between 5,000 and 8,500 rpm. Compared to the Power FC with 6 X 6 (= 36) load points.
Use one of the Datalogit outputs to control the thermo fan, and other items if necessary (eg; we control the intercooler spray)
Much more efficient (more power, better economy) to run the right sized injectors, than band aid in a separate fuel source. It could be argued that the PowerFC runs larger injectors so much better than the other (similarly priced) ECU’s and that’s why they have to have extra injector drivers.
:( cheers :dry:
ah, wondered about aux outputs on power fc, because never seen it being used, thanks for clearing that up...
wolf3d can be set up to use either MAP / MAF / TPS for load reference. (actually you can use MAP as primary sensor, and MAF as transient sensor to detect fast changes in load)
now looking at MAP and TPS they don't operate on a wide scale. so when you floor it TPS will be the max voltage it can show and MAP will also do the same when you reach target boost. so from that point onwards your map resolution goes from say 20x20 or 30x30 to 30x1 or 20x1 as you are only showing increase in map points by the rpm increasing. configurable or not thats the operation, which lacks the resolution of th airflow meter equivalent.
with an airflow meter setup the airflow meter "load" or signal is always increasing as more and more air is being ingested by the engine.
so if the wolf (or XYZ ecu) use MAP and/or TPS then they are no worse off than each other and don't provide a better method. the best being airflow meter and measuring the air directly. the rest appear to be workarounds or bandaids to work around the age old "airflow meters are a restriction".
if its a restriction get a bigger one, if its too small, get two
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
