  • Replies 112
wolf3d accepts an external map/maf sensor input
it regards it's own map sensor as the "internal sensor"
So all you do is wire up the afm to the external input, i don't imagine you need anything special to do this. there are 3 pins on the ecu you need to use...
-signal +5v
-signal ground
-external MAF/MAP sensor
So once you have that set up, ecu will let you choose between Internal/External for
-Primary load source
-transient sensor (to detect enrichment and enleanment on fast load changes)
not sure about 2 afm's, but you should be able to just wire up one of the afm's and change the relavent table.... nothing wrong with doing that
just to add.
yes you might struggle to find an out-of-the-box solution for rb26dett. checking their website, i don't think they have a kit for it, which means you'll most likely have to manually wire it up. Which would be a pain!!
in any case, i really don't see the problem with using a MAP sensor, what you and sk are saying is true, but when examining a couple of graphs i've plotted from my car's
TP vs RPM with boost overlaid on the graph, in most cases when boost is constant, TP is also constant (using afm as the input source), so it doesn't really matter if it's a 20:1 mapping or whatever, there is only one line on the map that it needs at full boost..... this might not be true on other cars, but for all the data i've got from my car it seems to be the case.
Here is how to download the calibration file:
1. You will need to build a very simple cable as per attached pic. No level converter or electronic components required
2. Plug cable to grey socket on your F-con V Pro and other end to serial port on your PC
3. Use attached software to download the calibration file
An orange light will come up on your F-con while downloading the file.
Enjoy, share it with the world and post your files here.
Tom
Wolf has a GTR plugin and have for a few years.Theres lots of plugins from Wolf but the web page is a long way out of date.Many jap cars are covered and not BMW and Porsche etc They are now a lot better than some ppl want them to be and older V4s are upgradable.
I have done 1000cc injectors without drama and they run without resistors on low impedance injectors.Very strong contenders in the market with some very advanced features in the pipe line.
Competition in the market is a good thing making everyone work hard to stay current.
I would have to agree that the wolf site hasnt been updated for a very very long time.
I heard last year about data logging for wolf and searched there site last week and found nothing. Emailed Steve and received a beta test version same day. They really ought to update the thing.
There magazine ads do show the GTR etc plug ins though.
well i gave it a try but the light didnt come on and the file saved is blank.
just to check the pins you've used on that 9 pin connector are 5-green 3-yellow and 2-black right?
and stop hijacking this thread with wolf crap! :P
Guest Mashrock
i would have been asking the same question come next week..
have you got a better photo of them pins on that plug..
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
