Anyone know what white smoke coming out of the exhaust could mean? problem wise?
The car is bone stock cept for an exhaust tip and pod filter. On load and high revs, it generates white smoke. The doode claims that it's just condensation in the exhaust.
:D:O
https://www.sau.com.au/forums/topic/111036-white-smoke/
big burts of power at hte top end of the rev range, think its leaning out @ top, which case, pinging is strong posiblity, i havent bought THAT car, just antoher posiblity as im looking
ive got some stuff in mind but as im on allot of importers / dealers lists to buy at the moment if they get something in that somewhat fits what i want hte give me a call.. told him i wasnt interest straight up as he wants to much $$$ just hadnt seen pure white smoke before, it happens under load all the time, it is runninbg complete stock bar the intake pod and the exhuast tip, so yea, staying away
https://www.sau.com.au/forums/topic/111036-white-smoke/#findComment-2047701
i ould post the f**king threads i've searched... essentially the answers to the specific questions i have asked wornt covered... if you have a link or a f**king answer cheers....else useless requests to search and find something would be f**king useless aye?
do i have to state in every single post that A, have search found nothing?
shit i didnt even hold to thses forums, i searched a few other forums and even googled it but specific to lines and problems i find to many posible answwers, hence the question in the other thread....
what could i look for that could cuase this that would be naked to the eye if at all,
re:
james
cheers mate,
im talking pure white, like coloured smoke, white, no grey or blue or black, just pure white... still sounds like steam?
thought it was myt login, sory hun eh ^^
no descriptions of thie so far, back to googling the shit aye
f**k it, check the black line on monday, else il go with ugly silver and a scatch on the door.
Edited by scheris
https://www.sau.com.au/forums/topic/111036-white-smoke/#findComment-2047820
http://www.skylinesaustralia.com/forums/in...&hl=white+smoke
http://www.skylinesaustralia.com/forums/in...topic=99862&hl=
http://www.skylinesaustralia.com/forums/in...topic=88288&hl=
http://www.skylinesaustralia.com/forums/in...topic=85894&hl=
and from first link
brownish/black smoke = running rich
white or blue smoke = burning oil
Sounds like you have a bit of blow-by, symptoms of a leaking seal in the turbo or a tired engine. Running 14psi+ on a std turbo, i would suggest you start saving for a replacement :O
IMO opinion it could be blow-by as its only doing it under load and high revs. does you car have an oil catch can?
https://www.sau.com.au/forums/topic/111036-white-smoke/#findComment-2047925
myth: i can search
busted: i cant search for shit,
i musted typed in like 3 or 4 searches and i did get hits but nothing useful, i got 2 of those threads, maybe i didnt read em well enough cuase from what i could tell they werent EXACTLY the same,
though the first thread sort of gets the same response with a shitty question
under high load leaning out up top it blows white smoke for like 5-6 seconds, stock bar a pod and tip, basically nothing cept intake growl and it went harder than most on cat back exhuast with pod and boost controller uping to 12ish psi, it wasx ecu controlled with literally no mods, suspect now head gasket is f**ked and think its well worth leaving alone
https://www.sau.com.au/forums/topic/111036-white-smoke/#findComment-2050601
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
