Shaun Posted March 25, 2006 Share Posted March 25, 2006 (edited) GDay, Just thought i'd post up some updated photos of my car, as some people were interested last time. For those who dont know, its a 1997 RB26 with forged pistons, prepped rods, ARP fasteners throughout, all the usual oil control mods (sump baffles, N1 pump, restrictors), GT35 Turbo, Autronic SM4, Trust 4inch exhaust, 100mm intercooler etc. I also spent heaps of time making stainless heat shields to help reduce under bonnet temps. All the hot bits are also ceramic coated or wrapped (or both!). I started it for the first time in about 2 years last week and all went really well. Although its untuned, it still starts off the key with no probs; the Autronic is well worth the money in my opinion. Ive just got to clean up the Autronic wiring and wire in the Autronic boost controller. Im using a seperate solenoid and switches in the cabin so that i can select between 3 boost settings ranging from about 7psi to maybe 25psi. Then ill tow it to Silverwater Automotive where Dave will tune it for me. Im hoping for about 330 to 350rwkw, but as long as its responsive i dont really care. I went for the 0.82 turbine housing, so it should be good on the street. Im hearing a bit of reversion when revving, so i hope the housing isnt too small. i think the BOV (Tial) is a bit stiff due to no use for 2 years, so that should explain that. Does anyone have any experience with these turbos on my engine. Will it be too small?? Anyway, here's some photos. Edited March 27, 2006 by Shaun Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/ Share on other sites More sharing options...
patto1234 Posted March 25, 2006 Share Posted March 25, 2006 Looks sensational!! I'd love to have the funds to just go mental on my car like that. Hope it all works out for you. You've got one very jealous skyline driver here Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2047628 Share on other sites More sharing options...
Morgs Posted March 25, 2006 Share Posted March 25, 2006 Good to see the progress Shaun, will be awesome once its tuned. Going to be an awful lot of wheelspin with that combination Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2047636 Share on other sites More sharing options...
R32Big_boy Posted March 26, 2006 Share Posted March 26, 2006 That is a very impresive car you have. What radiator are you using?, i am thinking of doing a simliar thing in about a year or so. Also how hard was it mounting the engine? Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2048568 Share on other sites More sharing options...
Shaun Posted March 26, 2006 Author Share Posted March 26, 2006 Yeah, wheel spin will be a problem. Oh well. Im using a standard radiator with EF Falcon thermo fans that are mounted in front of the radiator, and i reversed the direction of rotation so that they push air thru the radiator. Theyre awesome. They push sooo much air. I spent heaps of time modifying the Falcon shroud and sealing the system though. Mounting the engine is easy as. Youve just gotta use the RB20 engine mounts instead of the RB26 mounts. If using standard turbos, the oil return line fouls on the passenger side mount though. Shaun. Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2048605 Share on other sites More sharing options...
silver gts-t Posted March 26, 2006 Share Posted March 26, 2006 hot! Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2048742 Share on other sites More sharing options...
RedDrifter Posted March 26, 2006 Share Posted March 26, 2006 What did you do about the front diff/sump etc? Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2048794 Share on other sites More sharing options...
Shaun Posted March 27, 2006 Author Share Posted March 27, 2006 What did you do about the front diff/sump etc? The front diff was cut off and the front drive shaft holes were welded up. Tomie sump baffles are also used. Then i used an RB25 gearbox with modified gearbox mount (the holes dont line up) and custom tail shaft. The shaft is custom because the RB25 yoke is bigger and the total length of the GB is also longer than the RB20 item. Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2049742 Share on other sites More sharing options...
mlyf16 Posted March 27, 2006 Share Posted March 27, 2006 DAMN!!! SHinY enGiNE!! should be seeing that in a car show... good job. Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2051321 Share on other sites More sharing options...
Let Me Drive Posted March 27, 2006 Share Posted March 27, 2006 very nice would love to be able to do that sort of thing to my car Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2051403 Share on other sites More sharing options...
Roy Posted March 28, 2006 Share Posted March 28, 2006 Cant wait to see the results and hear how traction goes with good rubber. Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2055968 Share on other sites More sharing options...
' Max Power Posted March 29, 2006 Share Posted March 29, 2006 Great looking engine bay mate, probably one of the best I have seen to be honest. Best of luck trying to get the power down to the road! Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2057806 Share on other sites More sharing options...
Sl!m Posted March 29, 2006 Share Posted March 29, 2006 That looks awesome Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2057887 Share on other sites More sharing options...
Sarumatix Posted March 29, 2006 Share Posted March 29, 2006 how did you wire the thermos if you don't mind me asking? and what shroud did you use? Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2058387 Share on other sites More sharing options...
Shaun Posted March 30, 2006 Author Share Posted March 30, 2006 how did you wire the thermos if you don't mind me asking? and what shroud did you use? The Autronic has an output for thermos, so my friend who is an Autronic wiz wired them in for me. Electronics is the only area where im a dumb arse, so i let him do it for me. You can even stagger the fans so that one comes on at one temperature and the other comes on at another. Anyway, he said its a simple job if you know what youre doing. Sorry i dont have specifics. I just bought some Falcon (EF?) thermos from a wreckers and extensively modified the falcon shroud to fit in front of the radiator with the A/C removed. Youve really got to make sure the whole system is sealed so that no air can get around the radiator. They work great. Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2059407 Share on other sites More sharing options...
Sarumatix Posted April 2, 2006 Share Posted April 2, 2006 I'm currently running a single EF thermo with a big radiator and it goes fine . Was more interested in the specifics which you answered . I wonder does a powerfc have similar thermofan controls? Link to comment https://www.sau.com.au/forums/topic/111041-some-more-pics-of-my-work-in-progress-for-those-interested/#findComment-2065014 Share on other sites More sharing options...
