Single Turbo Skylines
It is easier and cheaper to get big boost happening with a single turbo. The main advantage of the two turbos is for better response low-down. If you're not concerned with this then there isn't much point having 2 turbos.
Of course, the twin turbo setup on the GTR is better than the single turbo on the GTS-t. But the GTR owners doing the single turbo conversion are usually bolting on one bigass $10k+ Trust turbo or the like, not a small turbo off a GTS-t :D
I dont know about the lag difference between using 2 smaller turbos and a larger single. From what people have said and tried, is that the single can be equally laggy if not better than the twins due to all of the exhaust going into the one turbo to hel pspool it up and not being halved to run two of them. Hope that makes sense, Im very tired!!!!
When I decided to do a complete rebuild of my engine, I decided to go a large single setup instead of a medium twin setup like a 2835 or 3037S for a number of reasons.
Primarily, price. With a TT setup, you have almost double the costs in dump pipes, wastegates and the like.
A single setup only requires one dump pipe and one wastegate.
Also the large single turbo is less laggy than the above mentioned twin setups. My turbo will spool at about 4300 and keep climbing past 8800. My rev limiter is currently set to 9000rpm in an effort to make the engine last as long as possible. The turbo itself is good for 35psi which would create as much as 500rwkw at the wheels in a GTR with the correct setup engine.
A twin setup such as the 2835s or 3037s setup won't spool till after 5000rpm unless you do a larger bottom end like Munro.
What about rigging up a sequential turbo setup to a GTR? Is that common, or too much effort? Wouldn't that overcome the problem of lag and give the best response over the whole range?
I'm talking about mainly Japan, because i know there aren't too many GTR's out here comparitively, probably even less modified.
I think sequential turbos are largely a waste of time for a performance car. They only really improve driveability. They also lower your off-boost threshold so you'll probably find that you're always going through more fuel.
To overcome the disadvantage of not having a sequential turbo setup, launch from a higher RPM and keep the revs up.
Originally posted by brendanf
hoe lee fark that is a nice engine !!!!
Are you sure you couldn't have fitted a bigger turbo to that ???
Appreciate the comments all.
Yes I could have gone a bigger turb than that but this one suits my hp requirements at the mo :D The only thing is that if I do go bigger now, I need a new manifold which positions the turb further forward. I do know of a car running the larger turbo and it's making 460rwkw on PULP on a base mapping :eek:
The turbo itself isn't actually a T88 but a Garrett equivalant which was custom sized wheel and exhaust housing to suit my requirements of a faster spooling turbo. The exhaust housing is the size of a T78.
where can i get an intake pipe like the one on there?
Call Unifilter and they can sort you out. That's a 5" pipe they usually fit to trucks.
Dude,
Obviously you weren't looking close enough to the 2 cars :P
Ben's turbo is BIGGER for one, his intake piping goes down through the chassis to the bottom where the indicators are on a stock front bar, and most importantly, his car is white!!
His rocker covers are black (used to be red), and his radiator shield is a stainless silver piece.
His intake plenum ain't stock. His catch can looks different. He runs Tomei cam gears.....
Should I go on???
:shake: :shake: :shake: :shake:
Originally posted by INASNT
dave isent that engine pic of one of bens cars from race pace??
i have seen that engine bay in the flesh and your car in the flesh and things dont add up :confused:
:shake:
Guest INASNT
Originally posted by Leewah
Dude,
Should I go on???
:shake:
hehehehehe, smart ass!!
i always thought u had twin low mount turbos on yours?
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
