hey all.. im new.
i bought surfstagea's car yesterday and am looking for some info already...
ive been offered some coilovers for my car but they dont look right.
the front and rear are meant to have the (O) shape at the bottom?
the ones ive been shown have the (O) at the bottom of the front and a upside down U shape at the bottom of the other two...?
are these to suit the stagea?
everything i search for seems to come up with dead ends
thanks in advance
Ash (another happy stagea owner)
p.s. looking forward to chilling around on here a lot more
https://www.sau.com.au/forums/topic/111063-stagea-coilovers-quick-info-please/
hey all.. im new.
thanks in advance
ok mate the rear shocks u mention with the fork ends (u shape) are for a gtr, or a stagea 260rs which has the gtr rear end, so they wont fit a normal stagea. u need the gts-t style o holes and they will fit front and back, though the weight difference in the stagea wont be very suited to gts-t shocks. :O
hope it helps
Brad
http://www.skylinesaustralia.com/forums/in...opic=110354&hl=
I believe these will fit the Stagea.... after having my mags put on Friday, I had a good look at the suspn, and Im sure these would do the trick.
btw - WELCOME!!!!
Edited by Tangles
btw - WELCOME!!!!
hey mate those will not fit a stagea rs four. front end no problem, rears have the fork style ends and the stagea rs four have the o shaped holes. unless u put gtr rear hubs/brakes/diff/ custom length axles on like mine they wont fit.
gtr = fork end rears
gts-t = o ring rears
stagea rs four = o ring rears
stagea 260rs = fork end rears
just to clear things up abit :(
cheers
Brad
just to clear things up abit :drag:
cheers
Brad
UMMMM didnt clear too much up for me, sorry
the fronts I have are U fork end
the rears I have are O ring end
Im confused.........
Nope, the fronts are eye (O if you prefer) same as the rear. I have NEVER seen a Skyline R32/33/34 or Stagea with a fork front shock.
Front shock
Rear shock
:drag: cheers :D
PS; all of this info is in the Stagea Suspension thread, which is a sticky at the top of the Stagea page.
Edited by Sydneykid
hey tangles u r just getting em mixed around mate, bigger longer ones at the rear and the short stumpy ones on the front :D
LOL
Thanks heaps - that clears it up for me!!!!
I honestly thought the long ones (U fork) would be for the front.....
stupid me..... LOL
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
