Just want 2 no if i will make 200kwatw with the following mods 2 my r33 gtst
3" tbe with split front/ dump pipe and hi flow cat
hi flowed turbo
about 14- 15 psi
CAI
FMIC
After market ECU, probly PFC
Nismo 550cc injectors
Also am considering custom intake plenum
So wot do u guys think i will make with these mods?
https://www.sau.com.au/forums/topic/111082-will-i-make-200kwatw/
  • Replies 43
That's overkill, but yeh should do easily. Don't forget a fuel pump.
You can reach 200kw with the stock turbo. Just need fuel pump, exhaust, intercooler, an exhaust cam gear, boost controller and PFC.
yeah you should make 200rwkw, on that boost with a hiflow turbo
im making 200rwkw now with
PFC
FMIC
AVCR
CES Split dump
3" Exhaust
Stock engine and turbo is on 12 psi .
Im currently in the middle of putting on
Hiflow turbo
walbro fuel pump
z32 afm
Boost will then be taken up to 15psi
hopefully should be seeing a lil increase with power.
Gtr33 pump 150 second hand. direct swap. theres a howto guide on the Tutorial section. Should take you about 3 hours to fit? just take the old one out, swap wires, mash the new one onto the harness, put back in and done.
yep it will be fine. 15psi is too high and will cause turbocharger failure (on the stock one). make sure u have a heavy duty clutch. you may wish to look at a z32 airflow meter. no need for plenum intake mods.
there are some pretty keen dynos around.... a lot of the figures people quote with standard turbos and minimal mods is rediculous... dont worry so much about "rwkw" but how the car drives and a good tune....
i have destroyed quite a few cars with a lot more 'dyno' power.
I was told that 15psi was perfectly fine for wot im goin 2 do as its being hi flowed and will have no problems supporting that boost and this is coming from sum1 who knows a shit load bout working on skylines.
As fro the 200kwatw figure i just thought that it would b a nice figure 2 have my car around for day to day driving with the occasional trip to WSID. Wot im realy hopping 4 is to get into a mid to high 12 once i get a better suspension set up. Once ive done this ilol b happy and just concentrate on the rest of the car
my comment was based on the stock turbo (did you read the comment in brackets?). 15psi is fine for a hiflowed one. note boost doesnt make power, airflow does. also you should sort out your suspension first if you want a 12
yeah some pretty keen dynos, this power resulted in a 13.1 pass on street tyres that were half gone. Seems to be reasonable ye?
Rev210 id agree on the power for times but ( i have read your r33 gtst threads good reads aswell) you must be 1 of the best 1/4 strip drivers on this forum so you and a couple of athers could do the 170rwkw for 13 pass but you would have to agree that it would not be the norm
You in a real 170 could do it but more could not than can i think
james
Hi james,
By way of encouragement if you consider that the 170rwkw 13.3 pass had a 60ft of 2.3 seconds it leaves room for those of us who are still learning to launch the car, in that case I was hardly making a good case for my drag racing skill. The area of greatest improvement is to optimise the power average and response of the engine.
More attention to what the curve looks like on a dyno graph and less on what the peak value is. If you stop comparing power outputs and start looking at the shapes and values of these graphs on similar motors you get a better understanding of things.
What does that have to do with what i said?
i was comparing different dynos... congratulations your car was on one that was realistic. Then again 1/4 times and rwkw dont have a hell of a lot to do with eachother... obviously your car is well set up, there are plenty out there that arent
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
