All this Dyno knocking is crap! We use dynos to develop the best power band possible so if you dont have your own Drag strip in the back yard to test every change you make then use a Dyno.
Many of the fastest cars dont have wild power figures but very good (sorry to reuse this term but its the easyest) "average" power all across the rev range,600rwkw to run 12s is not smart.
  • Replies 43
Thats some hope for me! ahha 104mph can run high high 12's! 'YES'!
BUT for me to get a 60ft of 1.777 from my current 2.3-2.4 is a big ask!
ECR33 what tyres was that on? size/brand? drag radials/semis or street tyres?
i'm guessing a nice long burnout as well?.
what revs did you drop the clutch or did you ride it?
Ummm, no :thumbsup:
104mph is good enough to run a 12 using std turbo. I've done it on my old set up which had 190rwkw (give or take a few either way depending on the dyno used).
SEE HERE
and you have a 1.7 second 60ft :)
as you said it's possible but, I was giving the guy something more realistic to aim for with a modest improvement in his launch.
Fair call :)
I just wanted to point out that it isn't impossible and further to that, I might add that that time was done using standard suspension as well :)
GTshortie,
I was using 255/50/16 BFGoodrich Comp T/A radials at the time (not slicks :thumbsup: ). Those tyres needed a nice, long burnout to heat up on the first run, but really only needed a modest burnout for each subsequent run after that. I was dropping the clutch at around 5,000rpm and it used to hook up really well off the line. With a bit of practice, I was consistantly doing 1.8-1.9 60' times on these tyres.
Unfortunately, those tyres were around $400 a corner. I now use Mickey Thompson ET Drag radials (around $250/corner) which are just as good in my opinion.
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
