I'm about to buy a second hand twin plate clutch for the RB30DET, but before I do I want to know if replacement parts (driven plates etc..) are easy to source and what brands are easier to get hold of.
I'm looking at an OS gilken, HKS or exedy twin plater.
Has anyone had to replace parts in their twin plate before?
https://www.sau.com.au/forums/topic/111108-twin-plate-clutch/
Twin plates are all modular so it should be a matter of finding an authorised dealer in which ever model you decide to get.
I know that os giken offer a few different versions of their rebuild kits that range from just new friction plates, to all intermediate plates, friction plates and pressure plates, and you can still get cages and flywheels separate aswell. Parts can be sourced through otomoto.
Just have a look at prices before commiting to a purchase. A full replacement kit for mine including friction and pressure plates was about a grand from memory. That was a TS2A which is the smallest twin plate offered by OS.
  • 1 month later...
greenline quoted the following DELIVERED to SA for rebuild an OS Giken TR2CD (to suit SR20)
OS Giken Overhaul Kit A $846 (71,438 Yen)
OS Giken Overhaul Kit B $1133 (95,693 Yen)
Kit A=new x2 clutch plates, middle spacer plate, pressure plate
Kit B=above plus new clutch plate cover
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
