My Rebuild
shmiddy
 Share
ha shmiddy shes lookin good mate
i now have the bug
just fitted the kie office on the weekend and twisted up the boost
like you said though, you get used to it to quickly
does anyone know what boost settings the std coils can handle
  • Replies 112
Posted Images
mine are fine at i think 1bar and 457hp.. we couldnt go any higher though because of the coils.. mine are still stock atm so im guessing they can handle a bit?? justin it is an addiction man, im really not youst to my engine yet, baby it a fair bit because i want it to last me a bit dont even wana know what itll do when we wind her up as i have my hands full at 457hp..
Hey Shmiddy,
Firstly, nice work!
Secondly, do you have any dyno graphs you can post up so we can see the power curve (and boost response) of the GT35 with the 0.63 exhaust housing?
Also, do you experience any compressor surge?
Cheers.
yeah man ill post up the graph later, i have to drag the scanner out the draw...
also wtf is compressor surge?? i dont have a clue what it is., maybe steve test drove the car and can tell you cos im usless..
Thanks, that would be great.
Compressor surge is a condition that occurs when a compressor wheel is operating in the area near or on the surge line on the compressor map. For example, if a turbo's compressor is trying to flow 40lb/min at 15 psi at 3500 rpm (engine speed), but your engine can only flow 30lb/min at 15 psi at 3500 rpm, you will get compressor surge. The extra 10lb/min of air needs to go somewhere, so it ends up coming back out the compressor inlet. The turbo hesitates to flow any more air, resulting in the car bucking or shuddering. A turbo with a large compressor side and small exhaust side can be more prone to compressor surge.
Cheers.
Jason should be happy with it we reckon.
He is due to walk in the door soon straight from London and we have capped the rwhp at 410 on 15psi.
Apart from some poncams , the rest of the engine internals are stock so fingers crossed :) :)
Cheers
Ken
Yeah thanks Ken...very happy :)
Power comes on real strong...Love it...and nothing gone bang :/
still put back. wolf isnt switchin over, gota send it to wolf. managed to run the low tune at 480 odd hp at 19psi i think, graph is in the glovebox wcant be bothered goin to get it to find the enzacts, will post that graph up tonight..
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
