omg thats some crazy shit duncan, reminded me of a mate who try to scrape of some stickers of hes rear windscreen with a chisel hahaha same thing happened,
you just need to get one hair line crack and your end up with a million cracks in the windscreen
  • 5 years later...
Sorry to bring back an old thread guys.
But better this then starting a new one when the topic is exactly the same.
Currently got the rear wiper arm off. and im presented with the (roughly 23mmish nut that seems to be holding the last piece on)
Dont really have the dollars to invest in a new rear window. Currently soaking in wd 40 overnight and I plan on trying to remove tommorow.
Anyone done this before to have any tips that will help prevent a smashed rear window. (But actually involve removing the rear wiper :rolleyes: )
Cheers,. Luke
It only took me 5 mins to remove the rear window wiper,didn't need the wd40 either.
Grab a vice grip,put top jaw on bolt thing holding the arm on and bottom jaw on the bottom of arm and pop it off,you won't break anything.
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
