just wondering is it posible to fit 2x 15 inch subs in the boot of an r33 (in a sealed box, mounted behind the seat) how big would the box have to be? would i still have enough room left in my boot? i want the box hard up against the back seat with the subs facing rear of car, will i have to move the battery? will the vibrations effect the battery?
thanks in advance for the help.
https://www.sau.com.au/forums/topic/11112-2x15-subs-in-r33/
I have one 15" sub in my boot in a vented box... to get maximum sound outa it it needs around a 100ltr box which fills my boot completely not a skeric of room left... the problem with R33's is the shape of the boot and the opening from the fron tof the boot to the top seal is very short distance so its hard to get a box in there. Other problem is its hard to make a box where the sub faces towards the boot which is what u want becuase of this limited space. I am in the process however of workin gout how i can fit another 15 in there, i'll let ya kno when i done it how it goes :P
https://www.sau.com.au/forums/topic/11112-2x15-subs-in-r33/#findComment-186765
big datto.
im not finaticle about weight reduction. my car is just a fast street car, not a full on race car. i just want the pleasure of good listening.
YBSLO4.
let me know how you go i would be interested to see what you come up with.
https://www.sau.com.au/forums/topic/11112-2x15-subs-in-r33/#findComment-188395
There is a fair bit of space, but I'd say you'd have to cut into your tyre well (hmmmm!) to get the clearance or have a false floor. When my sub comes I might try and mount it there... although when I think about it your not going to be able to get a sub-box setup using that method or are you??
https://www.sau.com.au/forums/topic/11112-2x15-subs-in-r33/#findComment-204602
Id be really grateful if anyone can provide more info on this. Iv got a 15 in my existing motor (R30 hatch) and am getting my new 33 in a few days. I want to mount the speak facing the boot, vertically if possible, as this has given me a really good result in my current car.
I will also be looking into getting a second amp and a 10 in the near future. the fifteen is perfect for the tunes I listen to, bt there's a hole in my bass response at about 130Hz. I want to mount the subs facing the back of the boot with the amps on a rack flusk with the tyre well.
any advice on the depth etc of the r33 boot would be gratefully appreciated.
https://www.sau.com.au/forums/topic/11112-2x15-subs-in-r33/#findComment-209170
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
