Nissan Fast
Has anyone got an updated link to download the Nissan FAST program? one that works, all the old ones theough the site is a bad link. Or is there some1 that can do a check for me? Greatly appreciate it :)
:D:thumbsup:
Edited by scheris
cheers dude, black colour code and model spec,
GGKBRTFR33VDA----A
time to find out what that means
more and more searching... sorted
sweet
so that says its a 3325t rwd and thats pretty much it, cool
so it matches what i've been told, 97 model, black, awsome the body is in good nick, so just wait on the inspection tomorow and see whats what
then buy me a line and enjoy.... thats gona be one helova drive home
hehehe
then a few days off to swap some bits and put in my stereo, complete the exhuast and install the alarm
Edited by scheris
Hi sorry to be a pain but is it possible to get another vin check? The last car didnt too well in inspection and we've decided to go with a second choice. I'd greatly appreciate it :D
The vin is: 6U9000ECR33106664
Thanks heaps!
:mellow::)
funkymonkey
not to push you or expect you to go out of your way or anything dude,
i appreciate you doing it the first time
mechanical inspection comes out great on this car but the scrapes and scratches and a little hail damage.... argh... so long to find lol ow my other car is out of rego and I have to buy something .... spuen
well it sounds worse than it is, even with ugly bench of a wing on it, still awsome car and not to shity pricing
  • 3 months later...
Built: 02/1997
Original colour: KH3 (ext) K (int)
Model Spec: GGKBRTFR33VDA----A
Engine: RB25DET
Model: R33 GTS25t Type M
Trans: 5sp Manual
Drivetrain: RWD HICAS
Hey Funky,
I've been looking around for a couple of hours now for a skyline model codes break down for r33's and have come up with diddley squat so far. Mate, can you look up a vin for me please on fast?
6u9000ecr33146691 or break down the model number ggkbrtfr33vzaaaydm. I'm looking to purchase this car tomorrow and it would help me greatly if you could check it out for me. It has 40th anniversary badges on the c pillars but no active lsd and after market seats so i cant check for seat badges. Sounds abit fishy to me. Thanks mate.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
