Nissan Fast
Has anyone got an updated link to download the Nissan FAST program? one that works, all the old ones theough the site is a bad link. Or is there some1 that can do a check for me? Greatly appreciate it :)
:D:thumbsup:
Edited by scheris
cheers dude, black colour code and model spec,
GGKBRTFR33VDA----A
time to find out what that means
more and more searching... sorted
sweet
so that says its a 3325t rwd and thats pretty much it, cool
so it matches what i've been told, 97 model, black, awsome the body is in good nick, so just wait on the inspection tomorow and see whats what
then buy me a line and enjoy.... thats gona be one helova drive home
hehehe
then a few days off to swap some bits and put in my stereo, complete the exhuast and install the alarm
Edited by scheris
Hi sorry to be a pain but is it possible to get another vin check? The last car didnt too well in inspection and we've decided to go with a second choice. I'd greatly appreciate it :D
The vin is: 6U9000ECR33106664
Thanks heaps!
:mellow::)
funkymonkey
not to push you or expect you to go out of your way or anything dude,
i appreciate you doing it the first time
mechanical inspection comes out great on this car but the scrapes and scratches and a little hail damage.... argh... so long to find lol ow my other car is out of rego and I have to buy something .... spuen
well it sounds worse than it is, even with ugly bench of a wing on it, still awsome car and not to shity pricing
  • 3 months later...
Built: 02/1997
Original colour: KH3 (ext) K (int)
Model Spec: GGKBRTFR33VDA----A
Engine: RB25DET
Model: R33 GTS25t Type M
Trans: 5sp Manual
Drivetrain: RWD HICAS
Hey Funky,
I've been looking around for a couple of hours now for a skyline model codes break down for r33's and have come up with diddley squat so far. Mate, can you look up a vin for me please on fast?
6u9000ecr33146691 or break down the model number ggkbrtfr33vzaaaydm. I'm looking to purchase this car tomorrow and it would help me greatly if you could check it out for me. It has 40th anniversary badges on the c pillars but no active lsd and after market seats so i cant check for seat badges. Sounds abit fishy to me. Thanks mate.
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
